Projected horsepower
Old Aug 16, 2024 | 11:37 AM
  #721
Tommy42088's Avatar
I'll never understand why people skimp on a MAP sensor. It's only the most important sensor on the whole engine!
Andrew
that sensor was 70$, didn't think that was skimping out.
Old Aug 16, 2024 | 11:46 AM
  #722
Project GatTagO's Avatar
I was referring to eBay or Amazon sensors. Many of my customers use the LowDoller Motorsports sensors without many complaints.
But again, for a MAP sensor, I prefer Bosch or Rife or Holley (SSI).
Andrew
Old Aug 16, 2024 | 12:04 PM
  #723
Black_Sunshine_99's Avatar
Andrew
RIFE gets my vote, very happy with their fast-acting IAT sensor.
If you're running a FI application, this sensor is a must if you ask me.
Old Aug 16, 2024 | 12:05 PM
  #724
NicD's Avatar
7 Second Club
Are you planning on running 43 psi of boost anytime soon? There is zero reason to run a 4 bar map sensor on a combo like this and all you are doing is introducing more error in the sensor by not utilizing it's dynamic range. Yes I know they claim the sensors are accurate within 0.5% throughout it's entire range but that is certainly not what I've seen. Hell one guy went through 3 of them in a row and there was a 5 kPa spread between them at key on.
Old Aug 16, 2024 | 03:32 PM
  #725
Tommy42088's Avatar
Andrew
I'm not gonna lie I had an Amazon ctsv sensor on the truck and he wanted to take it off and put the one I posted in the picture. He said he uses the ones in the picture all the time and they work well for him.
Old Aug 16, 2024 | 03:34 PM
  #726
Tommy42088's Avatar
no definitely not, I won't go over 20-22 psi, i dont really question him to much on things like that because anything he has told me to do so far has always worked well and when I choice other routes I always ended up having to do what he originally told me to do.
Old Aug 16, 2024 | 03:42 PM
  #727
Tommy42088's Avatar
This is the one i had
Old Aug 16, 2024 | 03:47 PM
  #728
The issue is that there is so much counterfeit crap on eBay and Amazon, I just don't trust most vendors.
This one looks really similar:
Amazon Amazon
Andrew
Old Aug 17, 2024 | 06:26 AM
  #729
Tommy42088's Avatar
https://www.amazon.com/MACHSWON-Repl...s%2C103&sr=8-6
Andrew
I definitely understand that, I hadn't had a problem with it but he wanted to change it and every time I go to his place it's full of turbo chevy's so he's doing something right and my truck has always ran well when I let him do something to it.
Old Aug 17, 2024 | 06:43 AM
  #730
My comments are more general and not necessarily pointed at your particular situation.
Andrew
Old Aug 17, 2024 | 07:09 AM
  #731
Tommy42088's Avatar
Andrew
I don't take it personal man, I'm not one of those and i take in all the advice i can get. From when i started building this truck until now ive learned alot between hands on experience, my tuner, and you guys.
Old Aug 20, 2024 | 02:36 PM
  #732
Tommy42088's Avatar
New intercooler fit right in. Sightly bigger but i like it better because i can put much shorter couplings.
Old Aug 20, 2024 | 02:55 PM
  #733
GMCGreg's Avatar
Patiently waiting on your results and track times. That intercooler is going to help I'm sure . I wish I could fit something larger in mine but beyond 3" thick is going to be a big problem and my whole combo is pretty much maxed out at this point which is fine because it met all expectations and then some for a street truck. Your goal is still a ten anything? Or you're trying for more ?
Old Aug 20, 2024 | 04:22 PM
  #734
dawgs74's Avatar
Andrew
Ive had just fine luck with these on oil pressure and fuel pressure senders and other non super vital componets only as secondary gauges and they always were within spec of what my primary gauges that the ecu takes its readings from……as for a map sensor…NO im with mr. Gattago, i would never use them as a primary vital piece….no way jose!!!….but as a generic back up gauge that isnt on my ecu handheld, sure if its gonna cost hundreds less and i already have factory and/or quality sensors/sendors in play already…..but too each their own
Old Aug 20, 2024 | 04:24 PM
  #735
Tommy42088's Avatar
Im ready myself too, i live it Louisiana and we have had 100 degree weather so thats really why i took the time to do it now, i wouldnt say it good track weather. Next month we should drop down in the 80's so my plan is to take it to the track then and I could probably get a little more out of it but I don't want to push my sbe to hard. 10 seconds is still the goal. It went 11.4 with the old turbo, stock transmission, 411 gears that were redlining 3rd and with back pressure issues and i can tell just by driving it that it pulls much harder then it did at that time so I shouldn't have any issues hitting my goal.
Old Aug 21, 2024 | 09:27 AM
  #736
Be sure to get some video!
Old Aug 21, 2024 | 09:49 AM
  #737
Tommy42088's Avatar
that's a must!
Old Aug 23, 2024 | 08:29 AM
  #738
C5_Pete's Avatar
I predict some more changes coming in the future if you run 10.10.
Old Aug 23, 2024 | 09:49 AM
  #739
Tommy42088's Avatar
lol you sir are probably right, it never ends
Old Sep 12, 2024 | 01:56 PM
  #740
Tommy42088's Avatar
18 psi
