How many of you are running a turbo blanket??
Old Jul 28, 2006 | 05:17 PM
Mr_president's Avatar
Default How many of you are running a turbo blanket??
well i was just curious how much a turbo blankit would help out?? what were your befor and after temps?
does anyone know where to get them cheep?
Old Jul 28, 2006 | 05:19 PM
Boostaholic's Avatar
Forced Inductions carries them, I plan to buy two for my car soon as I have a few bux to spare. I think they are about $75
When I do that and wrap my downpipe I'm hoping to lower my in bay temps by a few degrees.
Old Jul 28, 2006 | 06:51 PM
Country Boy's Avatar
Senior Member
Ill have one when I get my stuffs.
Old Jul 28, 2006 | 08:27 PM
MECHAM's Avatar
blankets and bottles are for babies...
Old Jul 28, 2006 | 11:46 PM
NOSjohn's Avatar
Restricted User
Give Jose a shout at Forcedinductions.com. I talked to him last week and they were getting more in this week. They help with temps a bit.
Old Jul 29, 2006 | 12:15 AM
2MuchRiceMakesMeSick's Avatar
I got my turbo blankets but still no turbos....
Old Jul 29, 2006 | 01:19 AM
Senior Member
LOL.. I have my turbo, but no planket (or hot parts)
Old Jul 29, 2006 | 01:29 AM
LSONE's Avatar
I remember hearing that they reduced the life of turbos because of how they retained heat, any merit to this?
Old Jul 29, 2006 | 01:35 AM
bboyferal's Avatar
Good question... I would assume at first glance that, because they're exhaust housings after all, they would not be affected by their own heat and that the turbo blanket would prevent some heat from escaping around the engine compartment. Moreover, I assumed it did all this with no consequence to the turbo...
Old Jul 29, 2006 | 07:47 AM
NOSjohn's Avatar
Restricted User
If you guys need turbos or hot parts, give us a call, we'll be happy to help.
As for heat, any time you run a turbo, you should ALWAYS allow a generous amount of time for cool down. Along the same lines, before getting on the gas, I like to allow ample warm up time.
Old Jul 29, 2006 | 08:30 AM
bowtieman81's Avatar
Good questions and comments in here. So, what is the benefit to running a turbo blanket? Is it just to keep underhood temps down, or is there a benefit to power?
Also, what is the best way to insulate surrounding pieces from the turbo heat (say power steering lines)? Should I use exhaust wrap and a turbo blanket, or should I use some heat reflective wrap on the steering lines?
Old Jul 29, 2006 | 08:41 AM
Senior Member
It could be both. It keeps the heat from the housing off the other parts and it keeps the heat in the turbine whick could help spool time. I got my housing coated and Im using a blanket. Gotta help the temps everyway possible.
Old Jul 29, 2006 | 10:31 AM
Stupid Boost's Avatar
Yup I have some on order as well. Usually they take a while to get. The manufacture that makes them for Forcedinductions is slow. Jason at Forcedinductions is looking for another manufacture already. They are definitely worth the money also. Probably cuts underhood temps by 200-300 degs or so.
Old Jul 29, 2006 | 12:05 PM
chuntington101's Avatar
i just read in a mag over here about a guys with a seven still kit car running a 2.0ltr Zetec turbo! he put a blanket on tboth the hot and cold sides of the turbo and said it made a BIG diffrence!!
just a thought.
Chris.
Old Jul 29, 2006 | 01:01 PM
What about raising the temp of the oil? Could that be a negative effect?
Old Jul 29, 2006 | 06:20 PM
ninetres's Avatar
i went to forcedinductions and only found them for $95 and up where are the 75$ blankets?
Old Jul 30, 2006 | 04:13 AM
WestSide's Avatar
we need a blanket gp!!
Old Jul 30, 2006 | 10:54 AM
ddnspider's Avatar
Ditto....im game
Old Jul 30, 2006 | 11:45 AM
I would be too.
DrTurbo's Avatar
LS1TECH Sponsor
We can do a GP for sure if you guys want. Send myself, Jose or Jason and e-mail and we can get something going.
