STS install pics... and stuff...
Old Jul 12, 2009 | 09:13 AM
  #301
ssvolvo's Avatar
Try the stock GM gaskets. I think you will be happy.
Old Jul 12, 2009 | 08:53 PM
  #302
99Ls1fever's Avatar
Some Very Good Info here, Thanks Guys!!!
Old Jul 12, 2009 | 09:38 PM
  #303
to-fst-4u's Avatar
I agree. The stock metal layered gaskets are hard to beat.
Old Jul 12, 2009 | 10:15 PM
  #304
ZL1Killa's Avatar
Originally Posted by firefighter813x
Nice setup. 420-430 would have been achievable with budget heads/cam and probably a lot cheaper too.
Probably, but a turbo to me is more fun.
The goal was a Turbo charged car with something different, not head cam.
I bought a used STS kit, did an intercooler.... a while down the road did a cam, did some minor tweaking and upgrades. enhanced the engines breathing capability. Cleaned some things up, and now I'm preparing to head back to the dyno, see my power level, do some tweaking, bump to 7psi, see if the 60mm turbo is holding me back, decide to upgrade or not.
I do agree that a head & cam setup car can make what I made turbo'd by bolting on my kit, hell a buddy of mine makes 474HP and 437 TQ on a head & cam car. But there is nothing like that turbo spooling up and it pushing you into the seat
Sure, my car may not run down the track many times, nor do I really have the experience to probably get it to its true times, but god is it fun to drive and sport around.
Will do, thanks !!!
Old Jul 13, 2009 | 05:50 AM
  #305
t/a-Donnie's Avatar
Originally Posted by ZL1Killa
...but a turbo to me is more fun.
......But there is nothing like that turbo spooling up and it pushing you into the seat
...but god is it fun to drive and sport around.
Agreed!!!
Old Jul 26, 2009 | 06:25 PM
  #306
ZL1Killa's Avatar
~6.5 psi and made 453HP and 472TQ !!! I guessed around 460-480 (obviously hoping for higher), but now with the new cam it loves boost. The power increase per PSI is nuts...
this 60mm IS carrying me to 500 crank HP & TQ (*assuming a 10% loss); You will see that this graph has a lower HP, we were playing around with the tune, and found out my rear main seal was leaking so we quit, and this is where she was left.
I will post graph tomorrow, got to order some parts for some upgrades!!
-transmission & clutch & rear main seal (fixed crankcase breather problem...but seal was still leaking, so replacing), new wastegate spring....etc
Old Jul 26, 2009 | 10:13 PM
  #307
blazin's Avatar
How many ft of the coolant hose did you need to go under the axle? Did you just zip tie it? Also what size is the charge outlet on the 60mm?
Old Jul 27, 2009 | 11:38 AM
  #308
ZL1Killa's Avatar
you know those BIG THICK ones... (thats what she said!)
uh..the outlet is...gotta measure it. I'll get back with ya. someone else may be able to tell ya by then but I will check it
Old Jul 27, 2009 | 01:48 PM
  #309
mike13's Avatar
Are you talking about the oil return?
Old Jul 27, 2009 | 02:25 PM
  #310
SS Ryan's Avatar
what size piping did you use for your intercooler? im trying to order my FMIC and im not sure to do 3" or 2.5" thanks!
Old Jul 29, 2009 | 06:07 AM
  #311
ZL1Killa's Avatar
I don't think he is talking about the oil return, as I used a truck radiator coolant hose to go out of my turbo to the first LONG STS chassis pipe. As far as I know you have to buy it in a 3ft section... I could be wrong.
The STS piping is 2.5 i believe...maybe smaller..... mine flares out back and forth, I want to say that it is 2.5 also though.
What size turbo and power plans do you have?
Old Jul 29, 2009 | 10:02 AM
  #312
mike13's Avatar
I'm almost positive it's 2.25 I just bought oval tubing to replace the stock STS tubing that runs along the subframes and the ends are 2.25 circular.
Old Jul 29, 2009 | 12:54 PM
  #313
SS Ryan's Avatar
im about to install my STS 67mm kit. i talked to chris @STS he says the intercooler kits they sell come with 3" piping that. so i bought an intercooler and piping kit off ebay that has 3" pipes and the fmic is 31x12x3.. worst case scenario ill get couplers that go down to 2.5 or 2.25 to fit
Old Jul 29, 2009 | 01:50 PM
  #314
Frost's Avatar
Hey Steve, in regards to your rear main seal... what's your PCV setup like?
Old Jul 29, 2009 | 02:53 PM
  #315
taws6m6's Avatar
sorry guys don't mean to hijack, but does anyone have any kind of brace for their rearmounts? Any pics?
Old Jul 29, 2009 | 05:05 PM
  #316
ZL1Killa's Avatar
its fixed now, we know why we are/were leaking out the rear.
I upgraded to the new ls6 valley cover w/breather
one valve cover breathes through a breather
then from the intake manifold to the valley it is a one way valve ,which was a stock one but is now a LPE one way valve good to 15psi. and we have it set the right way.
Old Jul 31, 2009 | 01:31 PM
  #317
eodmonkey's Avatar
Default a lil help?
hey this posting has helped me hugely in figuring out how to do my sts install. i have the kit off of a previous ls1 camaro but it looks like the cut a bit off of the wiring harness and i dont have any instructions. whats the deal with wiring it up? the pump looks like it has 3 parts to it. where do they all fall into place? any help would be great
Old Jul 31, 2009 | 02:07 PM
  #318
SS Ryan's Avatar
I'm in the same boat beginning my sts install tonight. They only instructions it came with are pictures with a few words here and there. Maybe ill do my own write up ..ha ha
Old Aug 1, 2009 | 08:19 PM
  #319
eodmonkey's Avatar
yea i saw a copy of those instructions. that a load of crap they are. apparently theres another set, an actual full set floating around somewhere. i've got a shop in nj the guy said he's trying to get his hands on. an oil pump should be easy power ground and a remote to turn it on and it just runs. wtf? i was thinking ball bearing and not needing to oil it so much
Old Aug 1, 2009 | 11:06 PM
  #320
ZL1Killa's Avatar
I have the STS manual, however I think STS has made a new one, as they have changed the kit and made some changes.
if anyone needs it, I can email it, but please be patient, it is 4 rar files and they are 2mb each....email sucks these days... what happend to sending 5mb emails quick, lol.
3 parts? Should have 2 wires for two terminals, and a IN and OUT with brass fittings or stainless.
