STS install pics... and stuff...
Old Oct 25, 2007 | 07:00 PM
  #121
ZL1Killa's Avatar
Ok got my intercooler in
here yall go
install is hopefully going to be finished this weekend, tomorrow. here are some pics.
wondering if all the abs black plastic has to come out or if we cut it and only remove some of it.
we already have the front bumper off and we are looking at the black plastic...what all has to come off to mount this pts sts intercooler kit??
also wondering about the oil return...it doesn't matter where we return it (cept a few areas) as long as its above the full mark correct?
and our new bolts that we replaced the stupid 'stick up' bolts that hold the ignition packs with...its going to be the black bolts that are in the bottom picture
Old Oct 26, 2007 | 05:24 PM
  #122
ZL1Killa's Avatar
Default PTS sts intercooler- piping
well I was going to install my intercooler and piping BUT.......
Rust inside the pipes
Bent Pipe ends
Rust
Old Oct 26, 2007 | 05:28 PM
  #123
koolaid_kid's Avatar
Wow, that SUX! What are you going to do? Have you called the company yet?
Old Oct 27, 2007 | 09:19 AM
  #124
ZL1Killa's Avatar
already left 2 voicemails and i reckon they will call me back monday. but this is rediculous, i paid good money for this and this is completely unacceptable.
i gotta wonder if i will have my setup ready for the spring autofair at lowes motor speedway now, cuz i'm going to have to find another intercooler setup. and i really want to keep my foglights. at least now i know my measurements for the IC size...even if i have someone make the pipes for me
Old Oct 27, 2007 | 11:34 PM
  #125
Frost's Avatar
Man that's f'd up... my pipes were CLEAN one thing after another isn't it?
Old Oct 29, 2007 | 09:35 AM
  #126
ZL1Killa's Avatar
im probably going to get just an intercooler and have a buddy of mine that I REALLY trust do the work
...and also what they don't tell you is you gotta cut the STS pipe with the BOV on it and make it straight so you can use the piping in the first place...and that means that the BOV probably has to be remounted somewhere....oh well.
Old Oct 29, 2007 | 01:02 PM
  #127
Frost's Avatar
Are you sure that is rust? All of my PTK cold side pipes are aluminum; not steel, not gonna rust.
Old Oct 29, 2007 | 02:50 PM
  #128
ZL1Killa's Avatar
i rubbed one of them and rubbed and its def rust
Old Oct 29, 2007 | 03:21 PM
  #129
Frost's Avatar
So they sent you STEEL cold side pipes? WTF.... Sucks dude
Old Oct 29, 2007 | 03:49 PM
  #130
Seems like they are steel with a stainless coating on the outside, but not the inside. Very odd.
Old Oct 29, 2007 | 04:20 PM
  #131
ZL1Killa's Avatar
they said the pipes had to be sent off to get powder coated then they got them back and such
oh and just out of curiosity... I noticed that when i had my bumper off that there is a huge metal brace at the front of the car that the FMIC bolts to. How much actual airflow goes through the IC, as this metal bar that the IC sets against creates a pocket of resistance there and it makes it hard for air to flow through the IC. what are peoples temp differences? or should I save this convo for a IC thread... LOL, just got to thinking
Old Oct 29, 2007 | 07:26 PM
  #132
quik01ss's Avatar
what i would try to do first with those pipes of your is try to find something with a long metel neck and a wire brissle head to try to get that rust out but dont know if you could find something like that??
now about the fog lights i understand they look good and you want to keep them but is the going to be enough air flow just through the front plate cover if u do take it off i would imagine??
on my car i had to cut my support and hang the bracket on the 2 ends that i left on.....if i were u i would have just gotten the pipes from trt and get an ic from ebay IMO but im not knockin on what u have.....but reply on what things you do interested
Old Oct 29, 2007 | 10:26 PM
  #133
1_quick_ls1's Avatar
Go with Texas Rear Turbos Kit.. Get you rmoney back from PTS... and get your kit from him.... TOP NOTCH KIT!!! CLEAN PIPES... BIGGER INTERCOOLER... Probably cheaper!
Old Oct 29, 2007 | 10:58 PM
  #134
Frost's Avatar
I cut the brace behind the airflow area and painted up so it wouldn't rust. You really have to do this to get the air through there.
Old Oct 30, 2007 | 02:46 PM
  #135
ZL1Killa's Avatar
Ok, that makes sense.
Ok, talked to them today and they told me all of their pipes are mild steel and that they do rust (surface) but not enough to damage anything, and he said that they have been doing this for 6+ years.
So i asked why do the STS pipes not rust....then he said they are mild steel too. and I also said that I have no rust in them and the kit was used too. Still no rust to this day.
Old Oct 30, 2007 | 04:16 PM
  #136
Well, it's your choice, but I personally would not put rusty parts in my intake flow. JMHO. Best of luck.
Old Oct 30, 2007 | 07:26 PM
  #137
trtturbo's Avatar
sts pipes are hpc coated inside and out.
As far as the IC pipes not rusting enough to hurt anything, would you scrape a little rust off and throw it in your engine?
Old Oct 31, 2007 | 01:12 AM
  #138
ZL1Killa's Avatar
exactly... and its getting sent back and not dealing with them anymore. it was made with mild steel, i'm probably going to have my setup made from a friend here in charlotte. Probably order the IC from somewhere...as the IC i got was actually fine
Old Oct 31, 2007 | 02:59 PM
  #139
ZL1Killa's Avatar
Ok got a question, EPP and TRT from what it looks like use the same style IC, end tanks on each end level with each other
then there is PTSs' IC with the end tanks one on the top side and one on the bottom side
which one is more efficient thermodynamics wise... what im asking is what would dissipate and lower the intake temps more efficiently
PTS http://www.proturbokits.com/store/sc...?idproduct=193
SAME
EPP http://www.exoticperformanceplus.com....html?item=655
TRT http://www.trtturbo.com/LS1FMIC.html
I realize the difference in the surface area...but what i'm talking about is the way the air flows through the IC
And also with the EPP and TRT kit, you cut the front brace ... doesn't this take away from the structural ridgidity of the car/frame? my car is a daily driver and IF i was to get backed into or something happen to the front in a wreck...i don't want an intercooler slammed into my motor and then my motor be slammed into me in the car
Old Nov 21, 2007 | 01:27 PM
  #140
ZL1Killa's Avatar
PTS needs to be changed to a different name if you know what i mean
been calling them for 2+ weeks now, no calls back, no responses at all
