p0200!!!!!!!!!!!!!
two sets of new injectors 60lb and now 80lbs
new used harness
new ground to block
all three grounds are on the back of the head
06 5.3 running my stock pcm
new used harness
new ground to block
Mine was a result of the harness on the drivers side rubbing the metal bracket attached to the engine where the harness rounds the corner to go behind the engine between the firewall.
It would only do it when I got into boost.
I wrapped the harness with some black 'race tape' (duct tape) and have not had a problem since giving the harness that little extra bit of insulation.
