Better way to Wire Walbro than inline Splice??
As I understand it, if you can run a tap off the actual battery (Which I am)you can get 13-14 volts to the pump for optimum performance. The problem is Chris nor I know how to do that. Can anyone explain what's involved?
Most appreciated!
<small>[ April 18, 2003, 01:16 PM: Message edited by: StealthStalkerLS1 ]</small>
Use the existing 12vdc wire coming from your battery to your existing inline FP and hook it to #30 on the relay. Hook #85 to a ground.
Cut the 12vdc wire (gray) that feeds the existing in tank FP. Hook the FP side to #87 on the relay. Hook the other half of the 12vdc wire (gray) to #86 on the relay.
Now when you start the car the and the PCM tells the FP to turn on there will be 12vdc applied to #86 causing the coil in the relay to energize and making the connection between #87 and #30. This will apply the battery voltage to the new in tank FP. When you turn off the car the 12vdc will be removed from #86 turning the in tank FP off.
Be sure to put a fuse (20amp) on the 12vdc lead coming from the battery.
See link below for a drawing.
FP Hookup
John
<small>[ April 19, 2003, 09:05 AM: Message edited by: JNorris ]</small>
Seems like it would defeat the purpose since it is funneling back down to stock wire size from the new relay. Did you notice any difference in your FP with this set up?
Any particular reason you went hot to 87 vice 30? As 30 is usually used as the 'common' input. It can go either way I presume.
Thanks for the schematic and the info.
I also understand Chris's concern too. My theroy is that maybe the stock Gray Wire is running thru a few different circuits in the vehicle before it actually reaches the tank where as the dedicated 12volt supply is tapped right off the battery. Maybe we can have a look at that gray wire that feeds to the tank and see if it would be too much trouble to replace it with a heavier gauge wire. If it's too much then we'll just go with the above for now.
Thanks guys!
See ya bright and early there Chris!
Brian.
<strong> Shouldnt the wiring from the new relay to the in-tank also be changed to a larger size?
Thanks for the schematic and the info. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Chris,
Yes you would really want to change out all the wire to the FP but I do not think you can get the larger wire through the grommet on the top of the tank.
The voltage drop across the stock wire (16AWG? At 12ft) would be .49v assuming 10amps of current draw. 10AWG would be .12v and 12AWG would be .19v.
You are correct about using 30 verses 87. I will change the drawing.
since you already have a relay back there with your inline.. part of the work is already done for you. Same story with my setup. so it was pretty easy.. Just follow JNorris's instructions and you should have no problem.
