Replaced pinion seal, now major leaking
Old 09-14-2007 | 11:16 PM
916LS1's Avatar
Default Replaced pinion seal, now major leaking
I was getting some drips on the garage floor where the yoke meets the rearend, so I changed out the pinon seal. I had no leaking for about 30 miles, but now, I got some good-sized puddles on the ground and a little bit of whining on decel.
In looking at it with the driveshaft out, I can see oil underneath and around the inside of the washer under the pinion bolt. What went wrong here?
I followed the sticky and all other install info I could find through searching. Please help
Old 09-14-2007 | 11:36 PM
z28241's Avatar
Where did you get your replacement seal? I had the same problem after i had bought a new seal from car quest, same result as you. Come to find out according to new era performance, the 2002 seals are slightly different than the previous years. New Era says you have to get seal from the dealer.
Old 09-14-2007 | 11:53 PM
8a8mfh's Avatar
The new seal you have has a smaller ID as compared to the old one. The old type used one seal in the housing. The new type has a seal in the housing and a seal on the yoke. Heres a picture of the new two piece seal.
What I did was remove the seal off the yoke and leave it off, then you can get an old style seal. I always had a drip around the seal area with the original crap. Heres a picture 9,000 miles later . So '90s something or earlier 7.5 seal, remove the one off the yoke, enjoy a dry housing.
Old 09-14-2007 | 11:55 PM
916LS1's Avatar
I got it from the dealer, part # 12471523. It looked identical to the one I pulled off.
Old 09-15-2007 | 03:10 PM
IROC403's Avatar
check the pinion nut, maybee it not tight enough. if it moves up+down
it will whine+leak bad
Old 09-15-2007 | 03:59 PM
916LS1's Avatar
So where do I get this new two piece seal? Or is that the one I have?
Do you mean I should get an older two piece seal and use both pieces, one on the yoke, and one on the pinion? I don't think I understand, sorry for being a dumbass.
Old 09-15-2007 | 07:56 PM
8a8mfh's Avatar
The newer production cars came with two piece seals, one piece on the yoke, one in the housing. The problem is when you go to any autoparts store they give you the older seal which has a smaller diameter. I don't know what you did but what I did was put this seal in, the yoke fit too tight into it because of the seal part on the yoke. It lasted a few miles before it ripped apart and started pouring out.
I went to every auto parts store and they all list the old seal for applications that take the two piece seal.
The dealer didn't have it in stock.
What I did and it worked was get an older style seal, with the older style seal you have to remove the part thats on the yoke. So what you end up with is the exact same seal and yoke outside diameter as say a 1984 camaro with a 7.5 rear.
Hope that all makes sense.
I got the idea from a thread here maybe a year or so ago so maybe I can find it later and post a link to it. Someone else made me aware of doing it like this.
Old 09-16-2007 | 12:47 AM
8a8mfh's Avatar
Heres when I first learned about the seal. https://ls1tech.com/forums/gears-axles/480230-where-do-you-find-right-pinion-seal.html
It'll still get damp with oil if you install it dry, I used red loctite around it. I wouldn't use silicone or rtv.
I'll admit the last picture I posted was after about 100 miles, this pic I took tonight (was a pic of the LCA brackets, I cut that out for size) it's not the best angle to show pinion seal leakage but as you can see it's starting to rust so it's obviously not leaking out of the pinion seal at all, this is approx 9,000 miles and 12-14 months later. Don't know if it matters but I also switched to non synthetic gear oil.
Old 09-16-2007 | 02:22 AM
916LS1's Avatar
Now I get it. Thanks for all your help. This afternoon I retightened the pinion nut and put some blue loctite on it (don't have the red stuff). The whining went away, and after a 10 mile drive and 3 hours of sitting, there are no drips. If this fails I will do what you suggested and get a new yoke seal. The yoke fit through the new pinion seal pretty nice, it wasn't tight so Im sure I got the correct pinion seal.
But now I've got another question, I thought you can change a pinion seal without draining the fluid (I actually drained it during the seal swap). I attempted to take off the yoke only this afternoon, and gear oil came pouring out. Is this normal?
Old 09-16-2007 | 11:40 AM
winger4800's Avatar
What Gm basically did was use a speedi-sleeve to stop the common pinion leak problem right??? I had to get the seal from GM I have the part number somewhere if you need it....
Old 09-16-2007 | 06:17 PM
916LS1's Avatar
Well, the goddamn think is leaking again. So, what your saying is I need to go to the dealer, and ask them for a pinion seal AND a yoke seal for an '84 Camaro with a 7.5 rear? Or can I keep the '02 pinion seal on and just throw on an '85 yoke seal?
Old 04-27-2008 | 05:46 PM
stimpster's Avatar
I just had the same problem. I told the dealership they needed to replace the yoke seal and the pinion seal, but they didn't believe me. So when it leaked again, I brought them this thread. They replaced the pinion deal again, and it leaked again, so they finally replaced the yoke seal.
Pinon Seal Part# 12471523
Yoke Seal Part# 12479332
2002 Camaro SS with 3.42 gears. No the Auburn diff.
Old 04-28-2008 | 07:38 PM
1badragtop's Avatar
Remove the pinion flange and inspect for worn grooves on shaft. If you can feel anything while scraping with your fingernail, replace the flange. The seal should still be ok, but replacement couldn't hurt anything
Old 04-29-2008 | 10:35 AM
95GreenZ28's Avatar
Get it figured out?
