Midwest Chassis & Performance fab rearends... new pics
Old 01-29-2012, 01:22 PM
  #2741
LS1Tech Premium Sponsor
ssvert99's Avatar
you can jack up the rearend from the bottom yes. I suggest getting a small block of wood and use a paddle bit to recess an area for clearing the drain plug.
Old 01-29-2012, 10:44 PM
  #2742
2QuikTA's Avatar
What are the threads on the 1/2 studs?
Old 01-30-2012, 03:30 PM
  #2743
ssvert99's Avatar
Standard 1/2" lugs are 1/2-20
Old 02-01-2012, 04:56 PM
  #2744
Brian2001SS's Avatar
Thanks SSvert99. Good idea.
Old 02-05-2012, 01:50 PM
  #2745
Stang-Slayer's Avatar
Subscribed
Old 02-12-2012, 09:07 PM
  #2746
6 Second Club Moderator
LASTLS1's Avatar
Looks like what I need to get my et's down!! Great looking stuff!!!!
Old 02-13-2012, 03:31 PM
  #2747
ssvert99's Avatar
and a little fire under the ***! LOL
call me some evening on my cell when you're ready to do the mods to the rearend... season is coming quick!
Old 02-13-2012, 06:52 PM
  #2748
2QuikTA's Avatar
Anybody know the bushings that come on the midwest lca's?
Old 02-13-2012, 07:08 PM
  #2749
ssvert99's Avatar
We use aluminum CNC custom machined on all our suspension parts.
Old 02-13-2012, 08:05 PM
  #2750
wrd1972's Avatar
I cut a 1/4" plate, made a hole for the plug and welded it on so now the plug is flush. Before this my jack started to bend the bottom plate of the housing. The plate makes it totally rock solid and would make an excellent cheap addition to an already excellent product.
Old 02-25-2012, 04:10 PM
  #2751
SweeTbone's Avatar
^ How was your jack bending the housing? Was it just small dents or something?
Old 02-25-2012, 05:20 PM
  #2752
LASTLS1's Avatar
I can't wait to get my tires tucked in and your other new tricks!!
Old 02-26-2012, 12:23 PM
  #2753
2QuikTA's Avatar
What oil is everybody running after the break-in? Is everybody going to a synthetic or is anybody sticking with the Lucas 80/90?
Old 02-27-2012, 11:03 AM
  #2754
TransWS6Am's Avatar
I used regular old Valvoline 80/90 with 2 bottles of the ford additive. I also have the billet clutch posi though.
Old 02-27-2012, 06:35 PM
  #2755
allout06's Avatar
i ordered my setup on friday, are the joints on the lca's, T/A, PHB...noisy at all?
Old 02-27-2012, 07:28 PM
  #2756
2QuikTA's Avatar
I thought MWC in this thread said only 1 bottle after break in? I bought 3, 2 for break in and 1 for after.
Old 02-28-2012, 06:43 AM
  #2757
jetaws6's Avatar
They told me to use 80-90 non synthetic but after the break in you can switch if you want too.
Also I dont know if anyone else had this problem but I could not for the life of me get my tsp y pipe to fit through the cross member piece off the ds safety loop. I ordered a pacesetter y and it fits like a glove now.
Old 02-28-2012, 09:08 AM
  #2758
wrd1972's Avatar
The plug protruding from the bottom just got in the way of the jack pad. When I placed the plug in the middle of the jack pad, the thin metal on the bottom just started to give.
If one simply had a 2/x block with a hole cut of the plug to go between the jack and the rear, that would work fine. Or even better, the 1/4" plate welded as shown and now the plug is flush.
Old 02-28-2012, 10:11 AM
  #2759
Heyfred's Avatar
Weld a jacking pad on the bottom. When I installed one of Erics 9", I did the same thing, centering tubing over the drain plug. To remove the drain plug, put an extension on the rachet.
MWC housing with jacking puck.
Old 02-28-2012, 10:29 PM
  #2760
Blwn_by_Twins's Avatar
Hope to be getting the word my rear will ship this week. Thought it was coming last week, but no luck.
Quick Reply: Midwest Chassis & Performance fab rearends... new pics
