cutting the shifter
My friend did it in his LT1 and cut it to short. First time he banged 2nd hard he cracked his console. I would just try to find a short stick that is already at the length you want. There should be some out there. If you do decide to cut it, make sure you don't cut it to short.
Wasn't being stupid, was asking a question. Last I knew, Lou's short stick was only available for pro 5.0 and Hurst, not B&M. So instead of buying a new shifter and a shorter stick, I was inquiring to the possibility of cutting down the one I have. So stop being a dick.
However, if you want to disregard all of this and cut your stock shifter stick down anyway... be my guest.
Last edited by Ironxcross; 03-11-2009 at 08:28 AM. Reason: Because the OP wanted to have a pissing match.
just as a thought it might make your cupholder useless. im 6'1" and can shift with a large drink no problem, but if it were an inch or 2 shorter i couldnt keep one there.
I cut like 2 inches off my pro 5.0 shifter i had the ws6store shifter with didnt like it just cut 2 inches off and it sits perfect and does not hit the console, and i do not have the blocker bolts on. It is personal preference do what you like.
What brand die did you use? Did you need something special because the B&M is stainless steel? Thanks
[QUOTE=Nitroused383;11226615]I built my own shifter and it is perfect for me. I built it to sit at a 7 degree angle towards me. My car came with the ss hurst shifter and this is so much nicer to shift. Stainless steel ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm a little worried about threading stainless. What did you use?
