Doesn't it suck when...
everything on your car starts to fall apart? In the last few weeks I've had my y-pipe just break(didn't hit a dip or anything), window motor die(with the window all the way down), clutch start slipping, rear end started leaking.. and on top of the that I need an oil change and new breaks.
I'm almost at the 100K mile mark, so have to brace up for more
What sucks for me is that everything on my car is in perfect shape. Except my transmission. And of course that's the most expensive thing to fix (for me). Oh, and that stupid *** rattle which is the ONLY weird noise the car makes. I spent 4 hours trying to find it, thought I fixed it. Then did it again as I pulled out of my driveway.
Guess I can't complain though cause my car hasn't given me any issues since it was cammed about 14 months ago. I usually only do the basic maintence and get to spray it once in a while.. not bad for a daily driver
140K, no problems yet...except one of the t tops rattles occasionally, and a while back when I replaced the cats and exhaust manifolds for headers, I ended up having to get the car tuned because a code kept popping up, but I don't consider that a problem. It's part of modding.
LOL, I just got all new brake rotors and pads, new master and slave cylinder, changed all fluids, tranny, motor oil, clutch fluid, rear diff, Polished entire car with porter cable. All I need to do is flush my radiator fluid and rotate the tires. Hopefully I'll be done for a while. I'm getting tired of workin on my car. Just want to drive it and joy it.
