shopping for another f-body, should i stay away from 98'?
im looking at a 98 Camaro Z28 im just wondering if its a good year as for the PCM... i heard from a buddy of mine that the 98 wasn't a good year... why is that? im planning to build everything whole motor trans and rear... i don't think i would have a problem??
LS1Tech Administrator
Received 1,685 Likes
'98 PCM is a bit harder to tune for FI, but that's about it. Any good tuner can do it though. And if you plan to build the whole car, than the other minor differences for '98 (good and bad) don't even matter.
Overall, my '98 has been the best year of F-body I've owned. I'd buy another tomorrow if I was in the market.
I wouldn't necessarily stay away from a '98. Just find out all of the differences between the years and figure out if any of them will cause a problem with the goals you have for your car.
my dead stock 98 A4 car with 100k stays right up with my buddys 01 SS M6 1sc car w/50k. i even pull a little in 2nd gear on him. i believe there is a oiling issue that was fixed on the 99 and later. but i have no issues , even at 100k it still over 50lbs cold and 40-45 hot at idle. i just wish i had the LS6 intake.
1. Had different casting heads which had perimeter bolts and valve covers.
2. Ignition coils were mounted to the valve covers one at a time.
3. The water temp gauge actually works.
4. Only LS1 year to not have an oil life monitor
5. WS6s had single outlet exhaust (all others had duals)
6. Steering wheel controls were completely different part with indentations on the buttons, and were better built
7. Only year that Purple, Gold, and Green were available
8. Some very early Trans Am's came with LT1 style headrests
9. Rear hatch release was poorly designed and often caused problems releasing mechanism
10. Early model 98 Monsoon stereos didn't have capability to control 12-disc CD changer
11. 1998-1999 automatic transmission LS1s could be started in 1st gear even with the shifter in 2nd. Starting 2000, if you put the shifter in 2, it would start off in 2, even from a stop.
12. 1998-1999 LS1 cars had a smaller throttle body cam, which caused the throttle to open to WOT faster than 2000+ cars
13. 1998 cars had 28 lb fuel injectors from the factory
14. 1998-2000 cars had a larger cam than the 01-02 cars
15. 1998-1999 cars had more restrictive exhaust manifolds
16. 1998-2000 cars had an LS1 intake with EGR
17. 1998 and some early 1999 cars had blue outside rear view mirrors (Trans Am only)
18. 1998 only LS1 blocks had a much smaller cylinder sleeve that only tolerated a .005" hone
19. Last year F-body to use the old 15.5 gallon fuel tank.
20. Only year LS1 F-body to contain a gas cap with a tether long enough to actually hang from the fuel door while open
21. Only year LS1 F-body to not contain the famous GM black box used in the event of an accident to record up to 5 seconds of pre-crash data
22. 1998 only cars had a different PCV system with the PCV valve located above the passenger side valve cover
23. 1998 only cars did not have an idle adjustment screw on the throttle body
24. 1998 cars have a completely different PCM from 99+ cars
25. A production shortage of F-body cams caused the use of a C5 cam to be installed in F-body LS1s for a very short time
http://www.lastofthebreed.com/Servic.../FbodyDiff.htm
I love my 98. The only reason I would see to avoid one is if you want to use a handheld tuner like the predator. You have a pretty limited amount of tuners available for the 98.
1998
26. 98s and some 99 has blue tinted mirrors.
27. 98s have a different style water pump and used paper gaskets.
28. 98s/some 99s do not have an ashtray light
My 98 has that light too in the ashtray.
I have owned a 98 ss for about 2 years now, 28k-56k mileage, and have no "98 problems" as people say. It has run great, nothing has broken and I am happy with it all. My "ASR OFF" light just came on and won't go off, but that isn't something that is 1998 specific.
This is only an issue if you plan to rev above the stock rev limiter. But considering the OP mentioned a plan to build a whole new motor, this should be a non-concern.
