Need help fast!!! Broken bolt in head!
So I just got done changing all of my pushrods and I was putting the valve cover on when one of the bolts that holds the valve cover to the head broke off in the head. Now what? How do I take this out?
A buddy of mine called me frantic one night as he was putting on a timing cover on a 4.3 engine he snapped a bolt off. When I got there he was getting ready to drill the bolt out and retap.........I took a screwdriver and was able to slowly turn the bolt out by a piece of broken thread........when they break there is no torque holding them in anymore, most can be screwed out with your finger tips or a pointy object that can get a grip on it.
lol just take a flathead screwdriver (smaller than the bolt ) and tap in right on the center of the broken bolt turn left and itll loosen up u should be good to go afterwards
If it doesn't come loose with a screwdriver twisting counter clockwise on an abrasive portion of the snapped bolt, try using a Dremel tool to engrave a flat line across the top. The use a flathead to take that sucker out of there.
