help!!!! 408ci stroker
ok guys i need some input this motor is ticking me off its a built 408 stroker with lq4 block 243 heads stage 2.5 port job done by bully performance 202 intake valve and 106 exhaust and lunati voodoo cam 600 lift intake and exhaust 287/293 duration and comp cam ultra gold roller rockers 1.8 96mm typhoon intake with ported and polished throttle body to match after market fuel rails stock injectors and obx shorty headers. now i know i screwed up by using typhoon intake they are junk and the obx shorty headers even worst. here the thing this damn motor only making 378 hp to the wheels and 400 fbt i mean this motor should be putting at least 500 to the wheels or in the upper 400s. any input on the build will much appreciated. may be can point me in the right direction like where did i go wrong beside what i had mentioned earlier.
Try typing with some punctuation and paragraphs, that **** made my head hurt.
1) get some bigger injectors
2) get some long tubes
3) find out what the real duration at 0.050 on that cam is
4) get it tuned by a reputable person
But even with all that, I wouldn't really *expect* 500rwhp with that setup. Depending on who did the heads and what the actual size of the cam is I would expect somewhere in the mid-high 400s.
500+ usually takes a pretty decent cam and very very good OEM ported heads or aftermarket ones with a FAST intake.
Agreed with all the above, but if you're going to switch the intake and you need better heads, I REALLY consider making the top end LS3 headed and let it breathe. You'll flow a ton more air and it'll get you 500 wheel.
the cam at .050 duration is 237 intake and 243 exhaust. i already ordered my long tubes i went with american racing 1 and 7/8 they are little bit pricey but they are worth the money. the top end i'm going with AFRs or ls3 top end. intake i will get the fast 102 and tb 102 to match. but i really need help with what size cam should i get and what size injectors you guys recommend?.
damn the ls3 is that much more better top end than the ls2?
thats where i made a mistake not matching things up. i'm going to redo the top end and match everything up together cam heads and all.
You are not going to see 500rwhp out of that setup period, i got 10 more cubes, way better flowing ls3 heads, bigger cam, better headers, intake and I see somewhere around 530rwhp on a dynojet now.
your setup SHOULD make around 450, the injectors are holding you back change those out and you should see some HP, WE NEED MORE INFO though, at what RPM is this thing making power? is it leveling off early or what. my 418 was leveling off at 4500 and only made 400hp first time out, foudn out the fuel pump was no good out of the box and was dropping pressure after 4500rpms you may have the same issue, if you really want to see better top end power get rid of the 243s and get some ls3 heads, they are better designed for bigger cubes, 243s only flow so well on bigger cubes
Injectors are holding you back, but if the heads havn't been milled for the extra bore then you will have shrouding. 243's that have been gone over properly should give you good results. Remember a few years ago they were all that was available and people made good power with them. If the head work that has been done was for a stock 347 then that could be part of the issue.
