How much fuel is being burned at idle?
Like say over a 30 minute period at idle, how much fuel would your car go through?
This is for a 2000 Formula of course.
Also, any way to calcuate it?
That's what she said...
Find out the injector pulse width at idle (milliseconds), find out the injector flow rate for that manifold pressure (lbs/hr), convert to lbs/millisecond, multiply them together and you get lbs. Convert lbs of gasoline to gallons and you'll know. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
But how many times is it pulsing?
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Tech Resident
Originally Posted by KC21386
fill up the tank at the pump, read a magazine for 30 mins, fill up again?
you also have to make sure the gas tank is filled up to the exact same level. fill up with the exact same level until you get that *CLICK* when the gas turns off. i assume it clicks off at the exact same level every time?
or just fill till the neck is full and gas is spiling over on the ground..ha ha ha.. for real though you can fill the neck all the way up if you are careful and have an extra min or two at the pump
