differant motors
Hey I have been looking to buy a ls motor I think I understand the ls1 and ls6 are 5.7 then ls2 is 6.0 but what are these suv motors I see for sale lq4 and lq9 other then intakes what else is differant just from looking at a picture I* see the intakes are higher.
The LQ4 is the 2500 HD 6.0l Iron Block Truck Engine.. I used that in my Build.
The LQ9 is a 6.0l Iron Block as well, it's in the '06 and back Cadillac Escalades, and in the Silverado SS I believe. It's a higher Compression than the stock LQ4, the Pistons are different.
If you want to run it in a car you have to get the car Intake, Accessories..etc. It's best to stick with the Car PCM's. All the Heads are interchangeable, most of the Truck Heads flow the same as the Car Heads, they just need to be milled down to match the Chamber size.
