160 thermostat and still running at 210*
ok so i read everywhere about people never going over like 180/190 when they install a 160* thermostat so i installed one and my operating temps are still at 210* its like i didnt even change the thermostat. ive even tried leavig one of my fans running but it makes maybe a 10* difference.
Kleeborp the Moderator™
The thermostat only controls when to let the coolant start circulating from the block through the radiator...the radiator is what is responsible for the heat transfer.
Soooooo...if you have something blocking your radiator (like an FTRA, etc), or if you have a bunch of **** in it (sand, leaves, bugs, other crap), it won't transfer the heat very well. The thermostat has little to do with anything in the grand scheme of things...
well i have a brand new Griffin Race radiator from summit...like the ones all the turbo guys are using. all new flushed coolant and nothing blocking airflow.
is this true? i do have my factory temp guage in there but dont see how/why it would still red up to 210 if the engine was actually runnin cooler???
Curious, since these cars are bottom breathers...
Is your Griffin upright? If so, is your front grille open for airflow?
it is "semi-upright" i havent cut my radiator support yet as no turbo..yet...haha but it is still tilted maybe at a 75* angle. either way my lower air dam is still there. i just dont get it. could it be the mix of coolant? im not sure if i did a good 50/50 mix like that was required.
