Old 05-18-2016, 01:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Power Steering Cooling Success
Old 01-26-2012, 08:57 AM
  #181
sjsingle1's Avatar
Originally Posted by guy7bmwm83
How did you connect the line off of the cooler to the power steering rack? What did you use? I used a barb fitting that keeps leaking. I have tried two different ones and they cause a leak. I am about to try a third one that has a different design.
nothing special......just slipped the hose on and it works.......mine does not leak
Old 01-26-2012, 09:09 AM
  #182
777Shock777's Avatar
Which cooler did you get again?
Old 01-26-2012, 03:40 PM
  #183
sjsingle1's Avatar
derale
Old 01-26-2012, 03:47 PM
  #184
derale
Awesome I got that one too, so mine will look good like urs
Old 01-28-2012, 11:58 PM
  #185
I did it! I got my cooler working ) (I'll snap pics tomorrow).
Now I am seeing something odd..
My low coolant light comes on even when there is plenty of fluid.
(I think there might be just a little more then there needs to be)
I have tried squeezing the hoses and that did help a little, I then added more fluid to replace the escaped air.
The light turned off for a little bit but back on
I've drivin it about 20 miles and haven't seen any overheating signs on my temp gauge.. And after driving and it's at operating temp, I see the reservoir is very high.
Any suggestions or help? :/
Old 01-29-2012, 12:44 AM
  #186
Save the manuals!
wssix99's Avatar
Not related but it is a common issue. Lots of threads on it.
Old 01-31-2012, 09:00 AM
  #187
NoRegretSS's Avatar
Not so sure about the previous posters reference to PS fluid deteriorating trans seal components, here's why.
I 1st experienced a PS overheat at a HPD day @ RA that the MW F-Body folks were hosting.
The PS overheated to the point that the fluid was not only on the engine but was also visible streaking out of the LF wheel well. A few reliable Camaro owners recomended using a baster to remove as much of the fluid as possible then use a Dex 111 or better ATF to top of the resevoir, yes i ended up with a mixture of the 2 fluids. Once that was done I completed 2 more sessions that day and had minimal , if any overheating issue of the PS system. The explanation was that PS and ATF have similar chemical properties. 2 years and 10+ HPD sessions later all is well and on very rare occasions do I now get an overheating issue after a hot session on a very hot day. All that said it does make sense to isolate the PS cooling but has anyone noticed a change in the ease of steering with operating temperatures in the 150-180 degree operating temperature once the system is isioated from the heat of the engine????? Not exactly sure what that new operating temperature will be.
Old 01-31-2012, 10:00 AM
  #188
Save the manuals!
wssix99's Avatar
Nope. The benefits come in longevity for the pump and elimination of fluid overflows. The way to change the steering effort is to change the build of the pump - but they are already over-boosted from the factory. (See the link in the first post of this thread. That link also suggests that, for racing, the way to go is to make the pump less aggressive and give more feel/effort to the system.)
If you look back through the thread, I recall that folks are finding temperatures in the 160-180 range after the cooling change.
BTW - I'd expect that PS fluid is lighter weight and kinder to the pump components vs. the ATF fluid, which is designed for heavier wear. Probably not the best thing for a daily driver.
Old 02-19-2012, 12:34 PM
  #189
splitfinger09's Avatar
So after reading this thread I think I have everything I need. Please tell me if theres anyting else I need. Dayco upper radiator hose 71981, Derale 13224, and 4 bottles of PS fluid. Is there anything else I need? Thanks.
Old 02-19-2012, 07:10 PM
  #190
My LS-won's Avatar
OK.....for those who care.....my car is an 02 ss....my power steering has been whining for the past two years...it all started when a pump went out...i first thought ahh its nothing ill just replace it....well that didnt work long story short i ended up putting two more pumps in...still didnt fix the problem...so i drove around for a while with the whining....replacing the pumps didnt help so i ordered a rack...put the rack in...nope didnt solve the problem..so i decided to put another pump in and no were at persent time..YES my p/s fluid is the color you ppl speak of.....all this damn money and its the ps cooler....now thats solved ...should i worry about ps fluid in my coolant hurting anything ie water pump....havent checked the coolant to see if there is any ps fluid...ive had this problem over two years now....FML i wish i would have seen this a while ago...im worried about the motor its new has less than 10k mi on it...
this just adds insult to injury considering i blew two other bone stock LS1's due to a bad MAF....
Old 02-19-2012, 08:29 PM
  #191
My LS-won's Avatar
But.......im really goood at changing ps pumps...
Old 02-20-2012, 12:07 AM
  #192
_JB_'s Avatar
In one of my posts, I needed a coupler. I'd pick one up just in case if this is your only car.
Old 02-20-2012, 01:04 PM
  #193
guy7bmwm83's Avatar
Could you measure for me the length of the hose (number 14) in the attachment? Or anyone else that still has their stock cooler attached.
Old 02-20-2012, 04:18 PM
  #194
What is the coupler for and what kind do I need?
Old 02-20-2012, 04:19 PM
  #195
I dont have it apart yet but I can measure it when I pull it out.
Old 02-20-2012, 07:00 PM
  #196
guy7bmwm83's Avatar
Thanks, I appreciate it. Its the hose that connects from the factory cooler to the steering rack.
Old 02-28-2012, 10:20 PM
  #197
RebelExtrm02's Avatar
He is referring to a union. It's to connect two pieces of power steering rubber line together. You may or may not need one from what I'm reading. Some claim there is enough factory hose to make it to the aftermarket cooler.
If you're worried, just take one of the hoses with you into an auto parts store or home improvement store and ask them for a male/male union to fit that hose.
Can anyone confirm whether the factory p/s hose is 3/8 or 5/16?
Old 02-29-2012, 01:35 PM
  #198
GiggleJuiced_SS's Avatar
how could i tell if my ps fluid is mixed with my coolant in the ps reservoir? will it be brownish? because my power steering whines like a banshee, i thought it was low on fluid but its full lol. btw ive only had the car a cpl months. i guess if they're mixed ill be flushing both systems?
Old 03-01-2012, 08:06 AM
  #199
Yes and yes. Another tell tale sign is the outside of your reservoir being wet from the power steering boiling over from the coolant getting in it.
Old 03-01-2012, 12:52 PM
  #200
bboyferal's Avatar
God what a dumb idea that was... I guess GM did this to heat up the PS fluid quickly after start-up, same reasoning for ATF for the auto cars to run through the radiator for the tranny?
My red TA is manual with no PS cooler, so I have never had to deal with any of these problems thank God. Nothing goes into my radiator except for water from the motor.
Quick Reply: Power Steering Cooling Success
