Battery Dead after storage
So I went to change my oil and get the car ready to come out and the battery was dead as ****! I had a battery tender on it for 4 mo's. Battery is only 2 years old so with the tender on it I can't believe it shot craps.
Anyone have any problems with a tender frying a battery over the winter or was it just a bad battery?
Next year I think I will just take it out but thats a pain in the *** with having to reset all your head unit stuff.
the dealer i work for sells a factory battery tender (porsche dealer) cause these cars are never driven so i have customers come in and wonder why there batterys still die and they have installed a tender with my experience these tenders are designed to shock the battery but when the batt voltage drops below a certain threshold the tender will remain on for extended periods of time (also porsche batteries are still servicable on 911s) but anyways it boils the water out of the plates i have seen countless batteries come in completely dry and not more than a couple years old so the best way to store it is with the battery disconnected
LS1Tech Administrator
Received 1,564 Likes
If you don't want to disconnect your battery, you can do what I do:
I use a 2 amp trickle charger that cuts off automatically when the battery is charged. I hook it up once every 2 months during the typical ~6 months of winter storage (or any time the car sits for a couple months). After two months, the battery voltage is usually down to about 12.0-12.2v. I do NOT keep the charger attached once the battery is recharged (no "tending" feature).
This process has worked great for my seldom-use vehicle. I get 5-6 years out of a battery without a problem. My primary reason for not wanting to disconnect the battery is because I drive the car so little that it would take all year to relearn the fuel trims if I pulled the battery every winter.
