Cars with 100k+ miles
Old 03-14-2006, 09:53 PM
smokey1226's Avatar
Default Cars with 100k+ miles
I currently have a deal on a z28 camaro, its a beautiful car however one thing that scares me is it has 100k miles on the car (it has a new LS1 under the hood) SHould i even bite on this deal or what? The car is in from what i seen in pics, good condition. Im going tomorrow to check it out better and to take it for a ride. Im scared to death about buying any car with over that kinda miles because things start going wrong and im not looking for a money pit. SHould things be fine? What should i look for what should i check? Im going to have the car looked over by a pro mechanic just for ease of heart but i dont want to waste my time if i should turn away now?
Old 03-15-2006, 06:51 AM
smokey1226's Avatar
anyone?
Old 03-15-2006, 07:34 AM
WS6ta98's Avatar
I have a 98 Ws6 ans it has 125000 miles and the only thing that I had replaces on it was the clutch. If it a reasonable cost I would go for it.
Old 03-15-2006, 09:13 AM
Z28LS1camaroguy's Avatar
if it has a new LS1 under the hood what are you worried about?? if its a new engine then its like brand new as long as he took care of the car then i dont see what would be wrong with it.
Old 03-15-2006, 10:31 AM
turbols1_05's Avatar
My 98 Z28 has 125xxx and runs with the best. The Ls1 engine was built by God, so you have nothing to worry about!!
Old 03-15-2006, 10:36 AM
black01_WS6's Avatar
there is a guy around me that has 165,000 miles on his motor and no problems yet. as long as it check out and a decent price then go for it. also find out if it is a 01-02 engine as it has a ls6 intake, no biggie if not just saves you a little money down the road if you want to mod.
Old 03-15-2006, 10:46 AM
TJSZ's Avatar
106K on my 99' and still runs strong. If the price is right....
Old 03-15-2006, 11:52 AM
BTTM's Avatar
138000 on my '99 and it still throws me into my seat when I launch. No problems whatsover as of yet. Runs very strong. Just take care of it when you get it.
Old 03-15-2006, 12:04 PM
smokey1226's Avatar
How will i know for sure? He said its out of the 01-02 (not sure) ws6, so im guessing but is there something i should look for that means it has the ls6 intake? Thanks for all the help guys. Also im really going to jump on this car if the price comes to what i want it. He said money talks and he needs it bad so just about what i say goes.
Old 03-15-2006, 03:06 PM
if you can get it for 6 or 7 grand it would be a good deal
Old 03-15-2006, 04:33 PM
smokey1226's Avatar
He was asking 9-10k for it and im not going to offer anything near that because of the miles on the car and because the clutch will need to be replaced and w/e. Im thinking 7,500ish
Old 03-15-2006, 04:42 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
just over 110,000 miles...runs fine..have kept up maintenance though..thats the main thing...little things are bound to go wrong even if it just sat.
Old 03-15-2006, 04:45 PM
smokey1226's Avatar
thats what im looking for, but where should i be looking for things to go wrong. With it having a new engine im not worried about that but im worried about tranny, clutch, ect.
Old 03-15-2006, 04:55 PM
Gannet's Avatar
You need to exercise every little feature on the car. Open every door, hatch, compartment. Work every lock. Work every **** and lever. Work the seat adjustments. Work the mirror adjustments. *Everything*.
Look under the carpets, so far as you can. Check every window/door/trunk seal. Look for any stains or other signs of leaks.
Look for mechanical leaks before you start it. Let it idle a good long time before driving and look for leaks again. Shut it off and let it sit 10 minutes for a "hot soak" and try starting it. Drive it a good long ways, including highway speeds, and look for leaks again.
Listen for any sort of funny noise, both on the cold start, and also after it has been driven.
If it passes all that, probably good to go.
Old 03-15-2006, 04:57 PM
ask him what else he replaced with the swap over. when was the coolent, brakes, rear end and all other fluids changed or flushed. look under the car and see if its leaking any fluids. also check the oil, some people never do, and that would be a good indicator of how well he kept up on maintence. ask 7 then go up to 7.5
good luck
Old 03-15-2006, 04:58 PM
jinxedz's Avatar
118K and she just dyno'd 310/330... stock.
Maintenance has been done at regular intervals.
Old 03-15-2006, 05:10 PM
NHRAMAN's Avatar
Exclamation
.... ..EXCELLENT ADVICE....also if you get the car, change ALL the fluids--- the coolant and tranny, rearend, brake, and of course oil. [ and do not forget the BLINKER FLUID. ]
Old 03-15-2006, 05:29 PM
Demon_Speeding's Avatar
Everyone here has pretty much covered everything. Much of what will wear with time/mileage is crap that most of us upgrade anyway... Suspension parts, rear ends, clutches, etc... If you can get a good price on it and it passes Gannet's test I'd go for it.
Old 03-15-2006, 05:49 PM
CarrotcarZ's Avatar
148k on mine and the only major thing I had to replace was just a twisted axle.....but that was driver error LOL!! Car runs low 12s simple bolt-ons....
Old 03-16-2006, 01:13 PM
Abe99's Avatar
I have a 2000 TA with 143K miles and its leaking oil so make sure its not leaking oil and besides the clutch thats only thing i have replaced.
