How To Seafoam Your Car
Old 02-22-2007, 01:11 AM
  #401
99corvette's Avatar
Well guess what about 300 miles later and i have a fouled spark plug now.
Old 02-23-2007, 12:50 PM
  #402
taintedmeat's Avatar
That paint job pwns.
Old 02-23-2007, 04:37 PM
  #403
99corvette's Avatar
Thanks! ......im stilled bumed about having to change out these spark plugs
Old 02-23-2007, 04:42 PM
  #404
After the first time it's really not that bad. Once you get the factory plugs out and get some in there with antiseize on them, they'll come out a lot easier the next time. Just move the air tubes out of the way, coil pack or 2 or swing the rail out of the way on the pass side, and you're in business. Probably take an hour if you have the extensions and everything you need right there.
Old 02-23-2007, 05:12 PM
  #405
99corvette's Avatar
Yeah i changed them on my corvette, but the camaro looks a little harder. But the good thing is, all my emmisions crap have been deleted on the car.
Old 02-24-2007, 01:20 AM
  #406
MyTA99's Avatar
Originally Posted by CashMoney
Yeah I did this to the GEO and blacked out the sun with all the smoke Good way to **** the neighbors off
Someone needs to get some good video footage driving on the freeway and or neighborhood.
Old 02-24-2007, 01:32 PM
  #407
KrazyDan's Avatar
Just put the sea foam in the car, in about 10 minutes imma make a smoke screan!!!!
Old 02-25-2007, 03:59 PM
  #408
How'd it go?
Old 02-25-2007, 05:11 PM
  #409
KrazyDan's Avatar
How'd it go?
Went pretty smooth. Didnt smoke too much though. while idling it smoked very little. Then I took it for the "spirited" drive. The first time I went WOT, I left a huge cloud. Then after that it was pretty clean.
I was pretty nervous doing it since I had never done it before. I followed the sticky step by step, and it was easy. Good write up. Even changed the oil with my first use of German castrol 0-30.
Old 02-25-2007, 05:37 PM
  #410
SpdFrk1990's Avatar
I just seafomaed my 100k mile DD it really didnt smoke too bad it did for a sec when i pour the last of the 1/3 in then I shut it off really quick. When I started it back up it wasnt too bad tho even during the spirited drive it wasnt hardly that bad at all.
Old 02-27-2007, 06:29 PM
  #411
99corvette's Avatar
Well i changed out my sparkplugs today and none of them were fouled!? Maybe it was a wire? Ill find out tomorrow when i get my MSD wires put on. Has seafoam ever been known to clog up fuel injectors? thanks
Old 03-03-2007, 06:11 PM
  #412
ammuscleftw's Avatar
just bought some seafoam i my car has 59k miles it was stock when i bought it and havnt owned it for that long - my assumption is that it has not been done before so well see how bad it is
Old 03-04-2007, 12:10 AM
  #413
ok i just got done doing the seafoam treatment for the intake and TB and i am pretty sure this had not been done because it did smoke quite a bit i started it and let it idle about 5 mins before i drove off and when i got a few blocks down the road i got on it and had some kind of rattling noise which im assuming was piston slap or spark knock but after a little driving and im sure alot of smoke (it was nighttime) it seemed to have cleared up. i took it easy for a few miles after it rattled just so i didnt ruin anything and got on it again and seems to be all good and also seems smoother
Old 03-04-2007, 01:00 PM
  #414
chavez885's Avatar
just seafoamed oil and thorugh the vacum line,my god the vacum line was scary,motor was revvin all crazy and sounded pissed off...gonna start it back up here in a bit and see if we get a smoke cloud
Old 03-04-2007, 01:37 PM
  #415
lol yea mine did the same even after i "dumped" the last 1/3 into the line it hesitated for 1 sec then revved again i had to have my buddy shut it off - not sure why people said that the motor wanted to die when doing this im pretty sure its supposed to rev unles you pour it way too fast or something is not quite right
Old 03-06-2007, 05:30 PM
  #416
pcgamer4life's Avatar
Well I just seafoamed, stalled the engine out and she's soaking right now. An odd note, maybe mentioned before, when I first poured a bit of seafoam in, the engine revved pretty high and sputtered out a lot of smoke out of the brake booster line. It did this 3 consecutive pours, then it stopped... all's well now, just waiting to start her back up.
Old 03-09-2007, 12:17 PM
  #417
TtamNedlog's Avatar
I just had my plugs changed by a mechanic. Never heard of seafoam til today. I've got 71k miles on my car and would like to try this but ya think I'd be alright after just changing plugs? I also only have 1k miles on my current oil. I'm sure my fuel filter needs a change anyway though.
I DO have my old plugs still. But the reason I had a mechanic do it is because I coudln't figure out how to get to the plugs, and from what I've heard it's insanely hard to do. Would it be wise or worth the effort to put the old plugs back in, seafoam, then put the new ones in again? This is assuming I'd even figure out how to change them.
Old 03-09-2007, 09:23 PM
  #418
camarolvr69's Avatar
idk...i just dont see the seafoam fouling plugs. didnt foul mine, and i havnt really heard of it happening. not worth it
Old 03-13-2007, 11:31 PM
  #419
i420tom's Avatar
my plugs are brand new as well
Just did seafoam all is well
noticed a difference and smother idle.
didn't smoke as much as i though it would
no eclipse like some poeple experience
and couldnt find the areosal either
Old 03-14-2007, 12:29 PM
  #420
SpdFrk1990's Avatar
I seen the deep creep at auto zone its over by the pb blaster and other penetrating lubes.
Quick Reply: How To Seafoam Your Car
