alternator question
LS1Tech Administrator
Received 1,696 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The small red wire on the back of the alternator is the exciter/field wire.
It sends a small amount of voltage from the battery to the alternator when the ignition is in the "run" position to create an electrical field and "excite" current production from the alternator. The alternator will not charge properly (or barely at all) if this wire is damaged/disconnected.
Restricted User
so if i am starting to get a fluxuating charge (sometimes under 13 volts and sometimes over according to the gauge) and this is the 2nd alt that has done this, the exciter wire could be the problem? is there somewhere i can get a new plug/connector for this. as i have had to repair the plug once already.
You can get the plug at the dealer. Its like $20.
Here is a link to my thread concerning something of the like.
https://ls1tech.com/forums/generation-iii-external-engine/663061-low-charging-volts.html
I need help!
I need help!
the male end of this exciter wire usually has issues, it comes out often.....mine was tilted slightly and my battery started dieing.....the wire itself is pretty fragile....on some cars its black and thicker and on some its red and thinner...for example.....my friends boosted ws6 has a black wire....and my 99 ta has a red one
for those exp. problems, check the wire, the load and the connector itself.....if there are any other problems feel free to pm me and ill explain more.....WS6NJAX....u know where to find me
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
I just had it bench tested. I was low (about 10) and then jumped up to 14 it kept up at 14 consistantly try after try but I went ahead and just got another one anyway. I figure even if it is an intermittant problem it was better to be on the safe side.
