New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
Old 02-21-2009, 07:10 AM
  #421
stevieturbo's Avatar
And should work well with a bit of boost
Old 02-21-2009, 08:50 AM
  #422
tonys02slpss's Avatar
Cant wait to see it might I will be able to buy it for my SS
Old 02-22-2009, 04:22 PM
  #423
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,164 Likes on 757 Posts
Quick note, but if the intake was designed largely for the LSx swap crowd, then don't get too bashy on the fact that it might not fit a 4th gen.
I'n curious to see how it goes. There's plenty of room for a few strong performers, and right now the FAST 90/92 stuff with some porting is the king of the roost for 4th applications that don't require any cowl modifications.
Best,
Admin
Old 02-22-2009, 04:26 PM
  #424
nastychevelle's Avatar
they did a test in CHP magazine and picked up 36hp over a ls6 manifold but only 3lb-ft of torque (with 90mm TB also)
same issue they changed out a carbed ls1 (doesnt say which manifold) and replaced it with a fast 92 and 92mm TB and picked up 22hp and14lb-ft of torque
Old 02-23-2009, 12:55 AM
  #425
eviltwin_1987's Avatar
all the f-body people should quit bitching about how you should go with a fast instead of this intake. the edelbrock one wont even fit an f-body
Old 02-23-2009, 01:57 PM
  #426
JonCR96Z's Avatar
Well that settles it then. The new intake won't even fit an f-body. What have all this people even been arguing for?
Seriously though, that is one of the most worthless posts I've seen on this board.
Old 02-23-2009, 07:09 PM
  #427
Tobynine9's Avatar
It will be a while before I could pull it off but how about I do this? - I'm assembling a heads and cam LS2 for the 427 Cobra replica I've got on the way. Right now there's a 92mm FAST manifold with a 92mm cable driven throttle body on it. I'm gonna use FAST fuel rails and 42 lb/hr injectors fired off by a LS1 computer. By looking at the pics and measurements, the Eddy manifold should easily fit under the Cobra's lid. I can set up it all up and get it dyno tuned with the FAST combo first. We'll see what it puts down. Once I verify the Eddy manifold will fit, I'll order one and swap it, head to the dyno shop and re-pull.
We'll see back-to-back just how well it stacks up against the FAST, even if it won't fit under the hood of a 4th gen.
Old 02-23-2009, 07:52 PM
  #428
touge battle's Avatar
toby u sound like u have a good plan lol
Old 02-23-2009, 09:41 PM
  #429
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Talking
Originally Posted by AINT SKEERED
If you all already have a fast , why are you in this thread bashing the Edelbrock? I have a fast also on my trans am but would prefer this one for my Race car. Its a light weight Nova
It is called "buyer's remorse".
Old 02-23-2009, 09:42 PM
  #430
99_orange_SS's Avatar
sweet can't wait on the results toby.....mind if I ask who the kit is from, I worked for LoneStar Classics for a long time so I was just curious
Old 02-24-2009, 12:21 PM
  #431
Camaro Ken's Avatar
Has anyone used this intake yet? It has a nice look to it. (in black) But 30hp over an ls6 intake seems far fetched. It also requires aftermarket fuel rails... It'll probably do well with a procharger.
Old 02-24-2009, 08:50 PM
  #432
1999FirehawkLS1's Avatar
How much to tall is this intake from fitting under the hood of lets say my firehawk? lol
Old 02-24-2009, 10:49 PM
  #433
The hood is not the issue major issue since it is easily replaced, its the cowl....so roughly 1-1.5" too tall for the cowl as is.
Old 02-25-2009, 06:11 PM
  #434
hmmm dont solida motor mounts drop the motor a 1in or so?
Old 02-25-2009, 08:38 PM
  #435
Not quite that much....some solid motor mounts, a .5" k-member drop and a little hacking and this intake may have a chance for everyone. No way to tell until someone gets one and tries it though so only time will tell. If I have the spare money at the time I'll definitely do it cause I'm all about the customizing
Old 02-25-2009, 08:41 PM
  #436
heck ya i goin to give the ls2 pored a shot just to be diff and hopefully maybe prove a point if i didn't already buy it i would buy the edlebrock and make it work 2 lol
Old 02-26-2009, 12:42 PM
  #437
moosezloose's Avatar
I like the looks of it. It would be nice to have another alternative to the fast that actually performed.
Old 02-26-2009, 01:14 PM
  #438
UNDER PRESSURE MOD
The Alchemist's Avatar
Like I said before, Edelbrock caters to the Hotrodding market, and part of hotrodding is to customize stuff to get it to work for your specific application. Not saying that this won't work for f-bodies, but it might require some 'engineering'.
Old 02-26-2009, 02:10 PM
  #439
got-a-ls1's Avatar
if i was going to be putting in a drop k-member and hacking the cowl it would be for a blower. not an intake lol... not worth for an f-bod...
Old 02-26-2009, 05:17 PM
  #440
maybe to you but not everyone shares the same view...it would be a great intake for a drag car w/ a procharger or other centri superchargers...it also would be great for NA road racers....to each his own
Like Alchemist keeps pointing out and it seems no one understands....re-engineering and customizing is what makes hotrodding what it is...plus its half the fun anyways
Quick Reply: New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
