LS6 intake installtion help
Old Nov 7, 2009 | 05:03 PM
camAro242's Avatar
Default LS6 intake installtion help
I have 2 questions:
1.How do you remove the injectors from the intake?
2. What do yall do about the egr tube that is suppose to go into the intake, since the ls6 intake doesnt have one
thanks in advanced
Old Nov 7, 2009 | 05:07 PM
FASTEDDIE Z's Avatar
Unbolt the fuel rails and gently pull up on it .The injectors should come up with the rail . You ll need to eliminate your EGR with a block off plate for you exhaust manifold . Then have it turned off with a tune. Or you ll be cruising around with the 'SES" light in you face .
Old Nov 7, 2009 | 05:12 PM
NemeSS's Avatar
be wary of the oil pressure sensor located at the back of block.
it will very easily break. its a plastic body. and a apin trying to find one when you need it. also there like 20$, so take time and dont damage it.
also disconnect map sensor, brake hose, vac. hose befor removing.
take a drinkin straw and cut into small sections and split, to use on the rear bolts to raise them.
Old Nov 7, 2009 | 05:15 PM
camAro242's Avatar
I have already removed the intake,If i do delete the egr, and mass flow air senor i wont be able to pass inspection will i
Old Nov 7, 2009 | 05:27 PM
Do you have a visual inspetion in your state ?? If not ,as long as you "ses" light is off ,but it works , you should be ok . Like I said , you can have the the EGR turned off with a tuner .
Old Nov 7, 2009 | 05:28 PM
camAro242's Avatar
ill be gettting a tune as soon as i get a job and money but in the mean time i cant have the light on cuz my inspection is out already, in my state they hook your car up to a computer and it reads all (if any) codes on the computer
Old Nov 7, 2009 | 06:08 PM
Pitbull329's Avatar
Here in texas? Noo..
My check engine light is on, on my daily driver (removed a cat from each side, so it has 2 not 4) And when its inspection time, I disconnect my battery for a little while and plug it back in. Drive to the inspection place, look for cats(there) and o the other stuff they have to do. But they never plug it into a computer to check codes. And thats because I take mine to those oil changing places. They are pretty damn **** about this stuff.
Old Nov 7, 2009 | 06:15 PM
LS1Aggie's Avatar
He lives in Harris County where he has to pass the sniffer test on his exhaust. It isnt just a visual check there.
Old Nov 7, 2009 | 06:25 PM
camAro242's Avatar
yup what if i drill a hole where its suppose to be at? also what can i use to block the egr if i do decide to take it off
Old Nov 23, 2009 | 02:41 PM
camAro242's Avatar
i tried the break parts clean trick the other day but it didnt make any difference in the miss firing. I just took off my intake to look things over and discovered water built up around my head bolts and my intake was damp inside, anyone have suggestions on how why this is occurring?
Old Nov 23, 2009 | 03:44 PM
TheBlueKnight's Avatar
That's really weird. I'm not sure about that one. Have you watched my install video? Maybe there is a small thing you missed or something?
https://ls1tech.com/forums/generatio...old-video.html
Old Nov 27, 2009 | 03:14 PM
camAro242's Avatar
i beleive i found the problem to my miss firing and idle problems, i found out that i broke the oil pressure sending unit at the back of the block.
Could this actually cause all of the problems iv been having?
Old Nov 28, 2009 | 01:59 PM
No, your only symptom from breaking the OPSU would be your oil pressure gauge not working. That's what I was told anyway.
Old Dec 2, 2009 | 04:31 PM
camAro242's Avatar
does anyone know what size socket would fit the oil pressure sensor? iv searched the forms and found threads saying it was a 27mm but it doesnt fit on it
Old Dec 3, 2009 | 09:22 PM
JMRO's Avatar
I broke that darn thing the other day, 40 bucks to get a new one. I used a 1 1/16 socket to get it off. I did not have anything big enough to get the new one on, so I used some channel locks. It is difficult to get it tight but I got it snug and hoped for the best.
