Is running the engine at 160* and below safe?
I would prefer temps to be at least at 175*, but that takes 30 mins and by then I'm done driving.
Is there anything that could go wrong with running the motor that cold for that amount of time?
I never got that because my SES has been on for not having EGR AND AIR.
and it would still warm up in under 5 minutes I'd say (definitely by
the first traffic light, a couple of miles in to town). Maybe the
Meziere pump 'stat has some bypass that lets too much flow
through the radiator and has you cooling from the get-go?
The problem is the holes are too large and allow coolant from the radiator to flow thru the engine preventing a proper warmup.
I'm thinking of switching to a 160 with 1/16" holes instead and see if that helps warm up the car quicker.
jmx has a very good write-up on the Meziere here.
http://www.ls1howto.com/index.php?article=26
When the temps outside are 60* and above it takes about 10min to heat up to the high 160's coolant temps.
A funny story.
A week ago when it was 45* outside I was testing the car out and put the heater on full blast and it felt like the a/c on low.
That's why I didn't get one because I live in MN. For the few winter drives it would be too cold to drive with a EWP. The plus side will be in Summer where you will reap the benefits.
A funny story.
I reckon. You only need 1/16" to let air bubbles by and
keep the thermostat "in the loop". How about getting
a new SBC 'stat and starting with smaller hole diameter,
one hole, and only enlarge it if you find you are getting
temperature oscillation/surge during warmup?
Hook this sucker up to a relay- then to your water pump- and you should be all set!
Will also save wear/tear on your water pump since it won't just automatically be kept on all the time. I'd say setting it at 185 or so should be sufficient.
