Gut Cats and Stock Manifolds
I was thinking the samething. I reserched it on this board. They said that there would be alot of rasp (interior and exterior noise) because of the cats being hollow. Meaning that the exhaust gas will expand in the casing empty cats this will cause turbulance and it will circulate and disrupt flow abit but not too badly.
They said to expect at the least about a 5 hp increase. With a tenth improvement.
Hope this helps,
Adam
2002 T/A Firehawk #536 M6
Hope this helps,
Adam
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Another option is offroad tubes that replace the cats
(Mufflex; others?). This is an 8-bolt swap if you have
some concern with emissions testing, easy to do once
a year.
Gains are to be had from port-matching the exhaust
manifolds; as-cast they intrude into the port quite a
bit. Now you're getting close to the effort of header
install (but closing the gap between stock logs and
shorties as well).
a year.
shorties as well).
with my shock cats on i went to 13.52 @ 105 with the gutted cat i went 12.89@108 et slick with LM replace with dynomax so it 's up to you ...there' rasp noise by way stock ls1 can go high 12 ez to twista
to you
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
I already have the Sims and my buddy's shop is charging me 50 bucks to gut the cats but If its going to sound nasty then I might think of other alternatives. I wanted those new cheap headers but some advise me to swap my clutch first then the headers because they will be in the way.
WARNING: BAD TRADER STATUS
Originally Posted by 2KSSLS1
with my shock cats on i went to 13.52 @ 105 with the gutted cat i went 12.89@108 with LM replace with dynomax so it 's up to you ...there' rasp noise
There is no way you gained 6 tenths by just gutting the cats
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
a year.
shorties as well).
a year.
shorties as well).
Originally Posted by greekss
where do i get these replacement cat tubes ???
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
https://ls1tech.com/forums/generation-iii-external-engine/135136-best-affordable-y-pipe.html
Originally Posted by 98SS Blackattack
