Which one, lq4 or 9 to buy for a fully built 4l60e?
Old 05-05-2014, 09:24 PM
R-Steffen 99ls1's Avatar
Default Which one, lq4 or 9 to buy for a fully built 4l60e?
I need to know which 6.0 I need to buy with my 4l60e to swap in my 99 trans am. I've heard certain ones won't match up. What else do I need to do the swap? The more info the better I need all the help I can get. I plan on putting a 112 cam in with a fast 90 intake and 243 heads.
Old 05-06-2014, 06:51 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Is this the transmission that came in the '99 car?
LS engines all have the same bellhousing bolt pattern.
Old 05-14-2014, 01:44 PM
Yes it is
Old 05-14-2014, 09:07 PM
Paul Bell's Avatar
Here's shots of the LS1 & LQ4/9 engine bellhousings:
Old 05-14-2014, 09:30 PM
Paul Bell's Avatar
You'll need to be careful about one thing: As I recall, the truck cranks had a wider rear snout and needed a different flex plate to accommodate it.
Some can jump in here to detail this?
Old 05-15-2014, 01:23 PM
gagliano7's Avatar
The early LQ4's had a longer crank(I think the ones with iron heads 1999-2000) those are the 6.0's that will be a problem.
Old 05-15-2014, 11:14 PM
So I need one out of the 03-06 escalade or what?
Old 05-16-2014, 08:05 AM
gagliano7's Avatar
Cadillacs have the lq9 if that is what you want.
https://ls1tech.com/forums/conversio...-question.html
https://ls1tech.com/forums/generatio...ck-please.html
https://ls1tech.com/forums/generatio...4-ls1-t56.html
Old 05-16-2014, 09:32 AM
Justus67's Avatar
There is a website that will tell you what engine you have, I'll try to post it this afternoon. Keep in mind the LQ4 has dished pistons .011 and will throw your compression calculations off if your counting them as flat tops. LQ9 has flat tops. You will also need a different flexplate.
Old 05-16-2014, 10:50 AM
Yeah I plan on bumping the compression up with 243 heads either way, lq4 or lq9.
Old 05-16-2014, 07:09 PM
Paul Bell's Avatar
It sounds like to accommodate the 4L60E flexplate that came with your F-body LS1 engine, you'll need an engine with the short crankshaft.
Old 05-18-2014, 04:58 PM
Anyone know which year range lq4 or lq9 that would be and what vehicle it's in
Quick Reply: Which one, lq4 or 9 to buy for a fully built 4l60e?
