true dual setup
Old Sep 23, 2005 | 06:39 PM
02ramair's Avatar
Default true dual setup
ok, im tryin to do a true dual set up. is the only way i can do a true dual setup is with bullet mufflers? or can i use some 30 or 40 series flowmaster mufflers, or a similar type muffler. the exhaust guy said i couldnt do it with the flowmasters because i would have no ground clearance. and i know a bunch of people on here have true dual setups. and i dont want to dump it because it rattles way too much. so im just looking for some advice. any advice is appreciated. thanks a bunch.
Old Sep 23, 2005 | 06:52 PM
Speed Density's Avatar
hashtagBMW
Yea man have you seen any pics of TD with bigg mufflers, you would have no clearance at all, on the other hand I dont know how you feel about rattling, i love that feeling!! You could try some Delta Mufflers from Flowmater, those things are realitivly small IMO. Good LUCK
Old Sep 23, 2005 | 07:06 PM
blue01ta's Avatar
Do a search. There was a guy who had a thread on this a week or two ago. Some guys are running Flowmasters in the normal setyup others use a bfh to beat in the undercarriage to make a little bit more room.
Old Sep 24, 2005 | 01:40 AM
Y2K SS's Avatar
Thats exactly how I got mine. No probs at all except for a little hitting on the rear end when I go over bumps hard. The Flowmaster mufflers go up right under the rear pasenger seats. They pounded them up a lil. Whole custom set up with chrome tips and all for 500.00.
Old Sep 24, 2005 | 03:05 AM
silver02Z's Avatar
Sweet Thunder or Flo Pro Twisters are good choices and tuck pretty well.
Old Sep 24, 2005 | 09:45 PM
mrr23's Avatar
seeing as you do not want to dump it, the bassani tru-dual goes all the way out the rear with no ground clearance issues. click the links in my sig to see pics.
Old Sep 24, 2005 | 10:24 PM
_JB_'s Avatar
If only Bassani made that kit for LTs...
Old Sep 24, 2005 | 10:25 PM
mrr23's Avatar
why not just do like i did and modify the pipes to go from the headers to the x-pipe. not hard to do.
Old Sep 24, 2005 | 10:32 PM
_JB_'s Avatar
But doesn't your setup have only one muffler?
Old Sep 24, 2005 | 10:37 PM
mrr23's Avatar
yes. dual in/out muffler. in stock location. that's why it has such great ground clearance.
Old Sep 24, 2005 | 10:42 PM
_JB_'s Avatar
So if I wanted to switch to a setup with Sweet Thunder mufflers, could I just put them in the location of the muffler on the Bassasini? I'm new to F-Bods' TD exhaust.
Old Sep 24, 2005 | 10:43 PM
mrr23's Avatar
yes you can.
Old Sep 24, 2005 | 10:50 PM
_JB_'s Avatar
Sweet. Does your car sound raspy? I know with the Y setups, without cats the cars sound really raspy
Old Sep 24, 2005 | 10:59 PM
mrr23's Avatar
nope. here's sound bytes from both cars.
http://www.vincihighperformance.com/...s1exhaust.html
under right pic
Old Sep 24, 2005 | 11:05 PM
_JB_'s Avatar
When people say "I-Pipe", I'm assuming it just means a narrow and long muffler? An "I-Pipe" is not the same as a x/h pipe?
Old Sep 24, 2005 | 11:07 PM
mrr23's Avatar
the I-pipe is the pipe that runs from the y-pipe to the muffler. I = intermediate pipe.
Old Sep 24, 2005 | 11:12 PM
_JB_'s Avatar
Ok, so on your setup, with the muffler removed and moded for LT headers, I could put two powersticks after the X pipe, or would it be better for the Powersticks where the muffler was at?
Old Sep 25, 2005 | 11:07 AM
Lane's Avatar
The only way to get decent ground clearance with 'box' style mufflers is to do this:
Flo-Pro Twister bullet style mufflers are the best overall IMHO. Great sound, less or no drone, and max clearance.
Old Sep 25, 2005 | 11:37 AM
FUN LS1's Avatar
This is probably a dumb question, but if you have tuned Long Tubes (I have SLPs), why do you still need the X or the H pipe? Is it just to balance back pressure, and if the tuned LTs are scavenging the exhaust, is balancing important anymore? My Loudmouth I pipe splits just over the axle to dual slash tips. I was thinking of having another I pipe bent to lead from where the I collector is now, and slapping a pair of the LM II modular resonators in line. The current original LM has just a resonator, but I don't think it's the same as the new modular one for the LM II's, so I'd buy a pair of the new ones, so they're the same on both sides... See the pic attached.
BTW - my clearance is aleady screwed by the SLP LT collectors
Old Sep 25, 2005 | 12:17 PM
_JB_'s Avatar
X and H pipes are to even the tone out. On my stang, someone didn't put a crossover pipe and it sounded like ****. One side would fire and the other would't.
