Any LS1 Carb engines out there?
If so, can you give me some tech info on it? Is there a place to pick
up an 8cyl ignition pulse in order to run a vintage street rod tach?
Care to scan the installlation / tech sheet info for me?
Thanks in advance,
Mike V
Thanks in advance,
Mike V
ill be doing this on my 408 that i get in soon...
you use the stock coil packs.... and MSD gives you software to use to control the timing....
from what i can see the MSD 6010 is a really trick piece... i cant wait
the wiring harness is extremely simplified its all wrapped in black loom...
it also comes with a tach signal wire, built in 2step, and built in retard function for nitrous.
I'm mostly interested in picking up the tach pulse and exactly
what it consists of. MV
id rather fax
pm me your fax number
https://ls1tech.com/forums/generation-iii-external-engine/105407-carb-intakes-ls1-s.html
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
https://ls1tech.com/forums/generation-iii-external-engine/148639-new-carb-ls1-setup-made-40-hp-over-ls6.html <<results
https://ls1tech.com/forums/generation-iii-external-engine/158658-gmpp-ls1-intake-availbility-update.html
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/173568-more-war-gmpp-intake-pictures-big-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/198601-gmpp-singleplane-tested-new-popular-hotrodding-mag.html
https://ls1tech.com/forums/generation-iii-external-engine/267311-carb-ls1-intake-converted-efi.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/305750-why-more-people-not-running-gmpp-intake.html <<pictures
https://ls1tech.com/forums/dynamometer-results-comparisons/311005-spm-hptuners-dyno-results.html <<dyno results
https://ls1tech.com/forums/generation-iii-external-engine/314549-carbed-intake-converted-f-i.html
https://ls1tech.com/forums/generation-iii-external-engine/320023-gmpp-carb-efi-conversion.html
https://ls1tech.com/forums/forced-induction/327044-new-intake-arrives.html
https://ls1tech.com/forums/generation-iii-external-engine/334178-who-do-machining-gmpp-single-plane-manifold.html
https://ls1tech.com/forums/generation-iii-external-engine/354540-vic-jr-intake-ls1.html
https://ls1tech.com/forums/generation-iii-external-engine/379735-edelbrock-victor-jr-intake-pics-specs.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/381677-various-single-plane-intake-pics-big-pics.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/392724-putting-carb-ls1.html <<Lots of Pix
https://ls1tech.com/forums/generation-iii-external-engine/414468-gmpp-intake-vs-edelbrok-victor-jr-ls1.html
https://ls1tech.com/forums/drag-racing-tech/425512-search-down-what-edelbrock-victor-jr-worth-over-fast-90-90-a.html
http://www.edelbrock.com/automotive_...ds_chevy.shtml
The MSD unit looks like it clearly has a 12v square-wave tach signal.
That opens the door to to "fuel-only" computers if say, you don't
want to run the factory PCM in a street rod or...<?>.
Mike V - "The Beast" ==>> <http://www.enzoco.com/mike/truck/>
cool....sorry i didnt get it to you sooner...
yeah im taking out my ECM and the wiring... lose some weight and im getting some after market gauges and speedo.... it'll be sick
The truck project is at www.enzoco.com/mike/truck/
Hydraulic brakes were considered hi-tech in those days
I'm doing this too, in my '47 Ford coupe! One thing I've found out: The MSD 6010 box is defintely NOT the same as the Edelbrock box included in their manifold kit. The Edelbrock box is a stripped down version of the MSD box with none of the extra features (2 step, vacuum/boost, programmable timing curves, or PC link function). The only thing that controls timing on the Edelbrock box is a preset "pill" that plugs in (they give you 6 different ones).
HTH,
Russ
HTH,
Russ
Mike V
mv
and it also comes with chips but its just to get you a good starting point.
