Oil in intake PCV test
Like could I just try cleaning it all and then leaving the oil cap off with the pcv disconnected and the intake capped off as a test to see if oil re-appeared on the intake / head ports?
Adding a breather on top of the stock oil cap won't work for me due to hood clearence, is there another kit that will replace the oil cap?
https://ls1tech.com/forums/generation-iii-external-engine/451559-how-remove-your-pcv.html
https://ls1tech.com/forums/generation-iii-external-engine/442131-what-do-pcv-system.html
https://ls1tech.com/forums/generation-iii-external-engine/466543-oil-consumption.html
https://ls1tech.com/forums/showthread.php?t=451559
On a side note I have had a M6 and it would use/loose oil since every time you go for a high RPM shift the engine free wheels for a split second and has no resistence on it and aloughs the oil to get sucked ito the intake via the PCV.
https://ls1tech.com/forums/generation-iii-external-engine/492344-remove-pcv.html
It maybe something to look into.
