Question about mufflers off headers and fuel line.
Old 09-12-2007, 04:42 PM
brandonppr's Avatar
Default Question about mufflers off headers and fuel line.
I was test fitting my mufflers strait off pacesetters. Whad do you do about it being so close to the fuel and brake lines? mine is touching.
Old 09-12-2007, 06:34 PM
Mark98SS's Avatar
I don't know where the Pacesetters end on the left side but on my Jet Hots I had to do up a short pipe with a bend to get the left muffler (3x12 bullit) in the right spot under the driver's seat area, right side was plenty of room.
Old 09-12-2007, 06:55 PM
GM Muscle's Avatar
If it's touching the heat shield (or obviously the lines themelves) then it's a no go. I've been there and done that. Boiled the brake fluid and I slowly lost the brakes on the way home from the track. Ended up having to use the e-brake by the time I got home.
Old 09-12-2007, 11:13 PM
brandonppr's Avatar
I was going to do the bfh mod to make it fit without an extra pipe. I have heard of alot of people doing it but just wondered about the lines.
Old 09-13-2007, 12:07 AM
5_02ls1's Avatar
your gonna have to add pipe to turn the mufflers in a lil...just go by a exhaust shop and explain to them what you need it shouldnt cost much for 2 pieces of pipe.....
Old 09-13-2007, 09:57 AM
WE TODD DID's Avatar
Gotta have some air gap!!!
Old 09-19-2007, 06:56 PM
brandonppr's Avatar
Page 11 on this link:
http://www.rolmfg.com/media/pdf/2006...retail2006.pdf
Would it be ok to use that or should I get a pipe made?
I bought one of those tubes. It seems pretty good and pretty smooth inside. I bought it so I could figure out how I need the pipe to be bent. I will have to get the exhaust shop to do it off the car, because they won't touch it on the car due to emmision laws. I was wondering have any of you used this pipe before. I didn't expect it to be a very good piece but after getting it home it seems like a well made pipe and might work just to use it on the driver side.
Old 09-19-2007, 07:21 PM
Demonicbird00's Avatar
that may work for a while, but it will eventually get brittle and crack. ive used it in kart racing and thats what happens to them after awhile.
just my .02.
i think it would be better to just get some solid pipe bent the way you need it and then youll be done.
-brandon
Old 09-19-2007, 07:56 PM
SPEEDYws6's Avatar
I wrapped the muffler with header wrap and cut a heater hose and put that around the fuel and brake lines. It's been working great for over a year. Before I put the header wrap on the floor board would burn my feet. Now I can put my hand on the muffler (the wrapped part) after a long drive and leave it there without getting burnt.
Old 09-19-2007, 09:32 PM
sixvi6-camaro's Avatar
I had the same problem and just picked up a piece of straight pipe for the driver side to extend the muffler out and used a vice to flatten a small section to clear the brace thing under the car.
Here is a pic of the drivers side on my car
and I pic of the pass side which is straight forward clamp on the muffler with the turndown.
Actually since these pics I change the angle of the turndowns to aim down more as well.
