Puzzling problem - please read!
Old Nov 12, 2007 | 06:32 PM
  #221
Tainted's Avatar
well lets hope that the 2nd time around is a charm then shall we?
Old Nov 12, 2007 | 06:52 PM
  #222
socmguy's Avatar
Restricted User
Let's not try any short cuts. Do it right the first time.
Old Nov 12, 2007 | 07:04 PM
  #223
crainholio's Avatar
My fingers were crossed for ya last time, but I'll do it again.
Old Nov 12, 2007 | 07:11 PM
  #224
SladeX's Avatar
the part about not following the torque sequence and claiming to be capable of doing this should be screaming alarm bells for everyone here...
at the very least, you should have someone around that's done this before.
I'm gonna sit and wait for the next 15 page monster I screwed up x item next...
Old Nov 12, 2007 | 07:41 PM
  #225
Tainted's Avatar
Well god damny all im sorry, I thought the ARP bolts, you just bolted down in order and you were done with it, end of story. I thought it did away with turning this bolt 50* and then turning that bolt to 75ft bls blah blah blah.
I had a bit of mis-information but now ive been re-informed with the correct info I need. I thank yall for letting me know that the ARP's still have a sequence, and I'll follow it.
Old Nov 13, 2007 | 07:09 AM
  #226
crainholio's Avatar
The only reason that was pointed out for you was that you blurted out your thinking here.
Imagine how many other incorrect procedures you have in your head that may have caused your first two engine failures.
This is why I point out that your "learn by doing" approach instead of reading the big thick service manual is going to be a long, expensive process.
Old Nov 13, 2007 | 11:29 AM
  #227
ArcticZ28's Avatar
There is a picture of the tq sequence and numbers for each of the three passes on here somewhere... let me find it for you.
Here, use this as a guide...
http://www.blackcamaro.com/headstud.htm
But, one thing I do differently is after the final torque, let it sit for a couple hours, then go over it again. Leave it sit overnight, then do one more pass. Never a problem doing it this way and it's the safest bet possible. Don't rush this one.
Also, my final torque was to 70 ft/lbs but that was b/c I have iron heads/block.
Old Nov 13, 2007 | 04:43 PM
  #228
8a8mfh's Avatar
I agree, scotch brite wheel on an angle grinder to clean even an iron deck is trouble.
Nice pics, yea they look like heads alright yippie.
Just run the head bolts down with a 1/2" impact.
Old Nov 13, 2007 | 09:41 PM
  #229
Tainted's Avatar
Sorry yall, been kind of irritable the last few days, ltos of family **** going on.
But thank you for that link, im actually printing it out now - however do those apply to just head bolts? I dont have the studs, just normal ol bolts.
As far as the learn by approach vs reading - its the truth, I truely can not do the reading thing, I have to actually sit down and do it, not read about it. Sure vie made a few **** ups, and expensive ones at that, its the way I learn and learn best.
Old Nov 14, 2007 | 11:53 AM
  #230
ArcticZ28's Avatar
Eh, I think bolts may be slightly diff tq numbers, but the sequence is the same.
Old Nov 14, 2007 | 09:38 PM
  #231
Tainted's Avatar
Ok, so is there any other sites that say the specific torque numbers?
Old Nov 14, 2007 | 10:46 PM
  #232
cam's Avatar
cam
torque specs...
*Note*
there are multiple passes for the head bolts dont mess this up! and dont forget the copper spray gasket and use fel pro graphites and I think you have a chance
http://www.ls1howto.com/index.php?category=1
Old Nov 15, 2007 | 11:51 AM
  #233
ArcticZ28's Avatar
For torque specs on head bolts...
http://www.ls1howto.com/index.php?article=2
Scroll down to "If using ARP head bolts..."
Old Nov 15, 2007 | 10:20 PM
  #234
Tainted's Avatar
schweeeet I printed out that sequence, much better than turning this and that bolt 50* and drawing lines all over the bolts.
I got stock GM graphite gaskets, but I always put the copper stuff on there just to help the gasket stick and not move around anyway.
Old Nov 15, 2007 | 11:03 PM
  #235
socmguy's Avatar
Restricted User
Well is that bitch back on the road yet or what?!
Old Nov 16, 2007 | 11:04 AM
  #236
ArcticZ28's Avatar
You don't need/want to use copper spray on graphite's.
Old Nov 16, 2007 | 02:44 PM
  #237
Tainted's Avatar
no? I'll make the copper spray yalls call. Yes or no.
Old Nov 16, 2007 | 03:53 PM
  #238
crainholio's Avatar
I vote no, since you're using graphite-coated gaskets. I only use copper spray/liquid sealant on uncoated shim gaskets.
Old Nov 16, 2007 | 05:13 PM
  #239
Tainted's Avatar
ok no copper it is then. Last time I used the FelPro gaskets from autozone and everyone gave me **** about them so I got the GM gaskets this time around.
Old Nov 16, 2007 | 05:51 PM
  #240
litle88's Avatar
Good now send me my damn video CHARLES!!
