Why run a big cam in a daily driver?
Old Oct 30, 2008 | 01:09 AM
  #101
lemons12's Avatar
Originally Posted by troopercar
I said that sarcastically. 10.9-11.0 is fast for a N/A street car.
I tend to be wary of those that are half a second faster than every other car with the same mods. Drag racers notoriously lie about their motors. Everyone is "all stock except this one little thing".
haha, ok wasnt sure if you were or not.. theres not many running around that i know of, lots on the juice, but not too many n/a.. i still get outran by a few if they spray me though... but some doesnt matter if they spray or not.. haha
i dont care to post my setup... no reason not to... i dont think? i get what you are saying though.. a lot of people "forget" they had a 200 jet instead of a 75.. hahahahahah... sometimes it still doesnt matter.... i look at it this way... if you have to lie about your setup, then you are obviously not proud of it.. im proud of where my car is for the time i have had it, so want everyone to know what i have..
Originally Posted by chrs1313
not bad didnt know you were running heads and a 90/90...hope you get it but what list are you trying to get on...
she is getting there.. yep, ls6 heads and a ported 90/90...
trying to get on this one!
https://ls1tech.com/forums/drag-racing-results/818893-all-time-fastest-n-stock-ci-h-c.html
specifically trying to get right in this area...
22. VIPRETR2 10.893@127.11; 02 WS6 Trans Am (346); Pro-Shift T56/RAM VDS; 4.11; stock LS6; TR230/224; 3450lbs; 12/07
23. Pro Stock John 10.92@122.53; 00 Z/28 Camaro (346); A3; Heads/Vindicator Cam; 10/07
24. Hugger 10.947@122.64; 99 Z28 (346); 4L60E; TCI-4000; Dart 225's; Comp 220/224 114; 3490lbs; 12/07
25. Chrs1313 10.9512@122.24; 02 Z28 (346); A4; SS4000; stock heads; 230/230; 3300lbs; 05/08
26. Camscam02 10.970@123.20; 02 Camaro(346); A4;4400 stall;stock heads;MS3 Cam; 3370lbs; 11/07
27. SuperSix10.985@126.12; 02 Camaro(346); M6;Spec3+; LS6 self ported; XP "Seaberg" Cam; 3340lbs; 03/07
28. Demonicbird00 10.998@126.93; 00 Trans Am(346); M6; Lingenfelter; stock heads;KOD Cam; 3260lbs; 04/07
29. ptero 11.131@122.79; '06 GTO (346); 4L65E; Vig 3K; TF225; HPE SCam; 3720 lbs; 12-16-'07
30. pirate3 11.16@121.95; 00 Z28 (346); TH350; TCI 4200; self ported heads; 242/248/.610/.615/111; 3350lbs; 4/08
Old Oct 30, 2008 | 10:36 AM
  #102
badmfkr's Avatar
Default my mild cam thoughts
Originally Posted by VIPERBLUELX
Well we installed a Paul Bunyan cam in my buddies otherwise bone stock 02 SS. 450rwhp ain't bad for cam only huh? Check out the dyno sheet, you can't imagine the power in that 1,000rpm power band. WOW.
you sound like a smart man.
that graph is funny as hell.
how did you like the folks that tuned the car?
my cam
DUR @ .004" 278*/ 286*
DUR @ .050" 216*/ 224*
LIFT .551/.551
OVERLAP 53*
LSA 115*
"THE BOSS FOR AUTOMATICS" "THE BOSS 115"
STREET / STRIP CAM / AUTOCROSS
POWER RANGE 2000 TO 6200
TUNING & STALL CONVERTER DESIRED
PERFECT FOR SUPERCHARGERS
POWERFUL CHOPPY IDLE
I have a mild cam and love it. very streetable power under the curve is where it's at for me. idel set at 590RPM.on a torqued car I don't like to hold the brake real hard at stop lights w/ a big cam at high idel it takes lots of foot preasure to just hold it at the light.
power comes on right from idel and pulls all the way to each shift point. my finale engine mod will be heads I'm matching each mod thats the key the sum of all the parts I'm expecting the heads to make a considerable increase.
the bigger cams make big HP #s but real low torque #s. my cam actually makes more torque than HP torque is what makes you go fast.
mild cams are easy on valve springs and are easy to tune my cam really didn't even need a tune I had it tuned mainly to pass emmisions (exhaust) thanks Vannerbuilt.
mild cams will not kill you're fuel milage like a monster cam will.
I have been smoking larger camed cars that just either missmatched mods or there way over powering there tires.
my 2 cents.
Thanks Joe & Roger at Vinncie for the cam
recommended reading
Do any shops market small cams anymore? why NOT?
Old Oct 30, 2008 | 11:50 AM
  #103
maggiemike's Avatar
Let me be the first to say, "Why not?"
Old Oct 30, 2008 | 04:03 PM
  #104
troopercar's Avatar
If it has to idle so high that you can barely hold the car, your converter choice is way off.
Wrong. I don't have the space or the inclination to explain it, but that is wrong.
I didn't build a souped up Z28 hoping for good mileage.
If a car has a traction problem, that means it needs less power?
So you raced a car that lit his tires up and lost so that means your mild cam reigns supreme? Maybe he just screwed up, even the pros do that sometimes. Or maybe he reserves his sticky tires for the track.
Come on man, I will lose to a minivan if its raining.
Old Oct 30, 2008 | 06:57 PM
  #105
derck_mullin's Avatar
Not sure if you can believe the hype, but this speaks pretty big to me...
http://www.gmhightechperformance.com.../photo_12.html
Basically the "donkey dick" MS4 pulls the stocker from the bottom to the top. I "think" what might happen is guys feel a big cam pull SO hard at the top the bottom seems lower. BUT as we all know the ***-dyno sucks. The donkey cams are making more power down low but it feels like less B/C the top end rush is so huge. I used to drive some turbo cars and it was the same...the BIG turbo always felt "weak" down low. It felt "weak" because the top end rush blew the stocker away.
Also, seems to me a big cam is an advantage for a DD because of traction issues. You probably don't run slicks on the street so as long as you get to the top of any gear you'll be launching without blowing off the tires and easily gaining on anyone else before you're out of the top of first gear.
Again, just my $.02
Old Oct 30, 2008 | 07:16 PM
  #106
lemons12's Avatar
+1.... you dont know what your talking about badmfkr... not calling you stupid, just ignorant.. and just because you raced a mismatched big cammed car, doesnt mean that they shouldnt be DD.... yours is built right with a mid cam, what happens when you race a well built big cammed car.. take a guess..
Old Oct 30, 2008 | 07:18 PM
  #107
lemons12's Avatar
9 TA WS6 A4 (3.23)200+MPH top speed 1/4 11.9 116MPH,cam,LTs,FAST,TC,Susp.
FWIW, i was at a mid to low 11 cam only.. no suspension...
not talking ****, just giving you some insight..
Old Oct 30, 2008 | 09:28 PM
  #108
VIPERBLUELX's Avatar
Again, just my $.02
You don't honestly believe that magazine BS do you? They'll print anything as long as the sponsors are paying for it.
Here's a GTO that swapped from a VRX3 (226/228 .585/.588) to a VRX6 (238/240 .605/.609)
If you'll notice this dynograph starts at 2,000rpms not 3,000 or so where some start. The big cam lost everywhere from 2000-5500. I'd much rather have that 30lb/ft down low back rather than gaining 10rwhp way up top...
Old Oct 31, 2008 | 07:40 AM
  #109
chrs1313 replied after me and his post disappeared?
Old Oct 31, 2008 | 08:45 AM
  #110
Nope...that was the reason I mentioned "if you believe the hype"....
Lots are turned on by big dyno #s and big BS...but I think a DD definition is hard to define. For some it's 60 miles and others it's only 10.
Also the gears and tranny play a big role...do you really drop to 2K rpms during a shift? Not likely...most will keep the tach spun to 4K or higher on a run the whole time. So, which cam is better? You should be keeping the motor in the meat of it's power on a run...shift at 7K and revs drop to 5K. Seems like the big cam is the winner...
Old Oct 31, 2008 | 08:47 AM
  #111
7,000 rpms with a stock bottom end?
Old Oct 31, 2008 | 08:55 AM
  #112
Sure...if you're feelin froggy
You do have an LS6 right???
Old Oct 31, 2008 | 09:02 AM
  #113
Yeah, but I think i'd replace the rod bolts before regularly taking it to 7,000. None of the stock style intakes out there will peak that high anyway so I don't see the need to rev a stock shortblock that high. That all comes back to picking the right cam for the combo I guess.
Old Oct 31, 2008 | 09:08 AM
  #114
True, true...
But what I was gettin at is you really do keep a big cam in it's powerband during a run...even if you shift at 6K you drop to say 4K. You might get jumped initially but it won't be for long.
  #115
JJD49's Avatar
Just curious what positive gains you see by running a huge cam such as the donkey dick in a daily driven street car?
What are the advantages in the big cam over say a 224 or 228 duration cam in the midrange of the curve(the part you'll be in most on the street).
thanks
Mark
We install them because WE CAN. Gotta love the big lumpy idle and the way the car just takes off with a slight push of the throttle
Old Oct 31, 2008 | 10:38 AM
  #116
Camaro396's Avatar
Big Cams Suck.
Smokin01ta ---- 10.219@132.29 (1.38), 01 TA, M6, Spec4, 4.56, TRex, -1100, 3010, 3/06
LS1Joe----------10.232@132.04 (1.39), 02z28, M6, Spec4, 4.71, 250, -1100, 3150, 03/06
01-z------------10.295@128.48 (1.38), 01 z, Th400, 5500, 4.57, G5X4, -110,2880, 4/05
Magnus -------- 10.295@128.48 (1.36), 97brd, T350, 5500, 4.10,G5X4, +200, 2820, 4/05
Dragaholic-------10.340@127.46 (1.36), 00 SS, 350, 5500, 4.56, TRex, -700, 2850, 11/05
SSmokedLS1 ----10.48@130.29 (1.45), 01 TA, M6, Spec4, 4.56, TRex, 800, 3035, 3/07
Trevor @ TSP ---10.510@125.80 (1.43), 98 Z, 4l60e, 4500, 4.56, MS3, -1000, 3175, 2/05
Project_SS ----- 10.561@126.74 (1.44), 98 SS,4L60e, 4400, 3.73, Vind, 2400, 2840, 7/07
DMcRacer-------10.738@125.06 (1.46), 02 SS,4l60E, 4600, 3.42, AMS, -1080, 3375, 1/05
Jason99ta------ 10.783@128.27 (1.56), 99 TA, M6, RAM, 4.56, TRex, +1300, 3253, 06/04
PewterZ28------10.857@123.53 (1.46), 02 Z, TH350, 4900, 4.10, G5X4, +46, 3310, 10/06
Coach02A3Z/28-10.917@122.97 (1.47), 02 Z, TH350, TK, 5.13, TRex, +2751, 3200, 06/04
Chrs1313-------10.951@122.24 (1.40), 02 Z, 4l60E, 4000, 3.23, 230, -70, 3350, 5/08
camscam02-----10.980@121.98 (1.47), 02 SS, 4L60E, 4400, 4.10, MS3, +290, 3370, 11/07
Bain------------
Old Oct 31, 2008 | 10:39 AM
  #117
Camaro396's Avatar
Alot of people spin stock short blocks past 7000.
Old Oct 31, 2008 | 10:41 AM
  #118
CaMaRo67RS355's Avatar
Originally Posted by Camaro396
Big Cams Suck.
Bain------------
YEP YOUR RIGHT THEY SUCK TINY CAMS RUN WAYYYYY BETTER
Old Oct 31, 2008 | 10:44 AM
  #119
thanks
Mark
your gains are alot more but you have to make up your mind with what the car is going to be used for street only, race only, both or what?? most people with larger cams arent concerned about streetability most are concerned with track times. then it has alot to do with who the hell tunes it. i went with the ms4 and drove it daily close to a year without any problems ran such as stock except for surging at lower rpms which wasnt a big deal to me. some people see the ms4 wayyyy too big for street use i dont at all worked very well for me.
Old Oct 31, 2008 | 10:45 AM
  #120
stock bottom end here my rev limiter hits at 7250 shift light is at 7000
