Stroker's come in
Build details:
Stock 2001 LS1 block bored to 3.905
TSP 383 Forged Rotating Assembly (Eagle 4"crank, rods, and Diamond -2 pistons)
Total Seal rings (file fit)
MS4 Cam
LS2 timing chain set
PRC 5.3 Stage 2.5 Heads milled to 59cc assembled
Cometic head gaskets (.051)
Melling High volume/pressure oil pump
Stock water pump, balancer, and ported TB
The night of the first startup, it was smoking pretty badly at idle (white smoke) and much worse while driving. Wasn't sure what was wrong so we checked the oil level and it had consumed 1/2qt within the first 30 miles. Added some oil, went another 30 miles, then changed the oil. I called TSP to ask what might be the problem and they suggested right off to put thread sealant on all the rocker arm bolts. So, we took out all the bolts and sealed them with thread sealant.
This did help the problem, but certainly didn't fix it. Now at idle, the car doesn't smoke nearly as much, but when taking off from a stop, I still leave a decent sized cloud. If I floor the car, it leaves a massive pollution cloud.
I called TSP back and told them this didn't fix the problem and that we were now beginning to think it was the valve seals. I was assured it wasn't the valve seals and that my engine is probably not breathing well enough and has too much Positive Crankcase Pressure.
Has anyone else experienced anything like this with larger cubed engines?
Am I correct in thinking it could be bad valve seals?
Any advice is appriciated. TIA
In other words was it assembled by TSP, or did you buy a kit and assemble it yourself?
Do you have previous experience in assembling engines? I am trying to figure out if you did any number of things which could cause your issues. In reading your post it says TSP shortblock. But, your posts talks about you assembling, disassembling,and re-assembling it. so, I am just looking to clarify.
We're here to help in any way we can, but there are other issues taking place. If sealing intake rocker arm bolts was missed other things could have been as well. You can replace the seals and rule it out, but I will bet money that your oil consumption issues are not affected.
Trevor
Texas Speed & Performance
I do not know the leakdown numbers because I was not the one who performed the test. The builder of the engine did and told me they were fine.
Engine was also broken in with 10w-30 VR-1 Racing Oil
Nope.
Disclaimer:
This is not a bash on TSP's heads, it could happen to any head of any brand.
