Beehive Valve Springs?
I was wondering if anyone uses the Comp Bee Hives for the LSx? With my custom cam Pat G said I need the Partiot "Gold" .660" Lift Extreme Dual Spring Kit, was wondering if there is any alternative. I like the Idea of the Bee Hives which is why I'm asking about them.
If Patrick recommended the Patriot Extremes, the Comp 26918 Beehives will not work. Patrick does not make these recommendations lightly. I would use exactly what he recommended or at a minimum a comparable spring.
Comp does have a few other beehive springs that could work but they would end up costing signifigantly more than the Patriot setup.
Thanks,
Shane
Thanks,
Shane
Thanks,
Shane
Thanks,
Shane
Some good info about installed height and shimming. What they don't tell is shimming while keepin seat pressures within cam specs will prolong spring life and provide better valvetrain harmonics.
www.cranecams.com/?id=5&show=faq
http://www.compcams.com/technical/Ca...106-07/294-295
