12.56:1 compression what fuel
Old 02-06-2009, 02:14 PM
383lt1impala's Avatar
Default 12.56:1 compression what fuel
what fuel should i run i dont really want to run leaded cuz i dont want to replace the o2 sensors often.
Old 02-06-2009, 11:18 PM
5.3LJimmy's Avatar
Can you tell me about the rest of your setup? What cc are the heads, what head gaskets, and what cc valve reliefs in the pistons? Using 62cc for the heads and a stock gasket thickness I get 11.96SCR and 8.77DCR. That can run on premium pump gas with a good tune. If I play with the numbers to get a 12.56SCR the DCR is a little over 9.2. Which is high for pump gas, but will be fine with 100 octane unleaded(if you can find it in your area).
Old 02-06-2009, 11:19 PM
Haans249's Avatar
E85 is good
Old 02-06-2009, 11:45 PM
slammer454's Avatar
Originally Posted by Haans249
E85 is good
you should be fine on E85.
Old 02-07-2009, 01:46 AM
heads are 70cc gaskets are .53 ccs i dont know my builder check everything and he said is 12.56 to 1. most of the info is in my sig. is e85 safe even wit a 300shot?
Old 02-07-2009, 02:32 AM
JonCR96Z's Avatar
It's hard to know what you need if you don't know anything about the engine. Using the numbers you gave on a 383 I'm having a hard time seeing 11:1 SCR.
Old 02-07-2009, 06:14 AM
LS1MCSS's Avatar
With a 383, .053 gasket and MS4 cam, I get 10.91. I think your builder is making a mistake in his math.
http://www.rbracing-rsr.com/compstaticcalc.html
Old 02-07-2009, 07:26 AM
elias_799's Avatar
^^^ he might have different pistons, witch raise the cr even higher.
Old 02-07-2009, 07:29 AM
Restricted User
2001 Pewter WS6's Avatar
I ran 12.5:1 on my 408 before I got different heads... Sunoco 93
Old 02-07-2009, 09:00 AM
Can't used e85 the nearest station is about 40 miles away. Ill just stick with some hi-octane unleaded fuel.
Old 02-07-2009, 09:14 AM
slow trap's Avatar
it must have dome pistons with those big cc heads and thick gaskets. if that scr/dcr is correct then i would run a 50/50 mix of 93 and 100 or more octane unleaded or the very least have a conservative tune in it for the street. if no one close sells 100 + you can probably order a drum of it from somewhere.
Old 02-07-2009, 09:33 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Well, the question I have is, is this a street car or track only? If it's track only, a lot of tracks have 100 octane on hand.
Old 02-07-2009, 11:53 AM
track car only very limited street use.
Old 02-07-2009, 01:16 PM
Nitroused383's Avatar
Tune it in speed densisty and get rid of the o2 sensors. You do not need them, run what ever fuel you want. Or just run it in OLMAF if you want to use the maf but if not just run OLSD. Either way no need to use o2 sensors unless you need them for emissions.
Old 02-07-2009, 01:39 PM
hmmmm i never thought of that good info!
