El Toro and matching heads...(swap complete, with video) post#1
Well I might be in the market for some decent heads for my car. What are some good options to look at that would match well with my camshaft ( specs in sig ) ??
**EDIT** Heres a video clip i made with my phone.
http://www.youtube.com/watch?v=9i4RoygG6lA
Ill take a look at the TEA's. The TFS might be a little more than id like to spend.
well i was poor when i got the car so i bought gears. then my trans went out so i got a converter. cam swap was cheaper than heads and seemed like a better idea so i did that. Now im bored and decided on looking at heads.
any ideas on hp gains with these heads??? PLus i cant seem to find any vendors other than tea that carry these. I kinda like the idea that some places have financing available lol.
i will tell you what from what i have seen with the TFS 220 as cast heads out there they are some of the best bang for the buck right now...i would definitely look into those or the TEA stg 2.0 ls6 heads are money also those were going to be the heads i was going to get till i stumbled into these 215 TFS's
this is what i should be looking at correct?? so it says using my cores makes the price a few hundred dollars cheaper. should i buy some used heads and send to them??? or should i just buy what they have??
The big intake valve on the that TEA head will cause PTV to be real tight. If you get those heads run a stock 2.00" intake valve and it will clear better. Call Mike at TEA.
They are good guys.....
And if price is the overiding factor pick up some 243's here or on the vette forum and just get a GOOD valve job and maybe some bowl blending if the budget allows.... You can always get them ported later.....
also, whats the best vette forum out there to look for a set of used ls6 heads??
this is a dumb question i'm sure, but who it TEA? i'm just getting into looking at heads and this is the perfect thread for me. I also have the El Toro cam and looking at getting into a set of heads. but i know nothing about whats good and whats not.
so what about an intake with an "el toro" cam and say a set of ported 5.3's. will a stock ls6 intake do ok? Would ported 5.3's be effecient enough, or should we go straight to ported 243's and not look back??
i have no idea lol. maybe one of the other guys can chime in here. however i will be running an ls6 intake since i dont have that kinda jack to throw out on a set of heads and a fast intake.
