Mill heads, thinner gaskets, or both for increased compression?
I'm just wondering if it'd be worth it to have a quench a little tighter or If I'll be just fine with stock gaskets and 11:1 compression
Ideally, cams of this size are ground on a tighter LSA to give you more options. Without the advance, 59cc's and a .053" gasket comes to just 8.05:1 DCR, leaving quite a bit of room to improve.
Check your cam card when you recieve the cam and see if there is any advance already ground in. It would be best to degree the cam to ensure it is installed correctly, then measure your PTV clearance. Shoot for .080"/.100" after cutting your pistons, and you are good to go.
LSA 113 109 ICL = +4 degrees ground in
