Another 5.3 turbo camshaft question
Old 01-04-2012 | 11:03 PM
280z28t's Avatar
Default Another 5.3 turbo camshaft question
Well good to be a part of this forum again it has been quite some time since i have posted but i have gathered a ton of information from this site over the years. I have been searching around the web (including the site) and im having a hard time picking out a camshaft for my 02 5.3 that im getting ready to swap into my car. This is going into a 78 nissan 280z that is currently setup with an all iron 355 twin turbo, reason for going 5.3 is cheap fuel injection. The car has a th350 manual valve body trans with yank 4000 stall. This is not a daily driver however im entertaining the idea of putting the 6 speed back in the car as it was way more fun to drive. From what i gathered the ls6? cam sounds like a good turbo cam but i hate how it sounds sooo damn smooth gotta have somewhat of a choppy idle... the race weight of the car should be around 2600 lbs.. the gearing is 3.7 planning to go to a 3.5, tires are 26 inches tall...i have already got the victor jr efi manifold with a dfi holley 1200cfm throttle body if that makes any difference. Im planning to keep running my chinese 60/63 t3/t4's as i have beat the absolute **** out of them with not one issue! and probably use a log manifold unless i can make the cast truck manifolds work on the car... Im very open to ideas let me know what you guys think!
Old 01-04-2012 | 11:12 PM
280z28t's Avatar
here is a few pics of the car
http://s1219.photobucket.com/albums/...iswith1nbitch/
Old 01-04-2012 | 11:27 PM
JPH's Avatar
JPH
Couple profiles come to mine for me:
228/228 .600/.595 113
232/230 .600/.590 114
Old 01-06-2012 | 12:48 PM
280z28t's Avatar
interesting, what would the power/ rpm range be with these cams?
Old 01-06-2012 | 02:16 PM
JPH's Avatar
JPH
Cams are very close, so the Larger of the 2 will probably RPM a couple 100 more if that. Expect an RPM Band of 2600-6200k with these profiles.
Old 01-06-2012 | 02:40 PM
wildcamaro's Avatar
For turbo cars i always recommend going with a cam profile that favors the exhaust duration that way you get an efficient spool up...im running a comp cam 224/230 on my NA ls1, but i think it would be great for your setup...def has the choppy idle you would be looking for
Old 01-06-2012 | 05:58 PM
280z28t's Avatar
im looking for peak power around 6500, currently my car crosses the traps at 122 mph at 5700 on the limiter, i figured 6500 plus the 3.50 rear end gears i will be able to get 130 plus through the traps and that should be enough to go low 10s which is my goal. I am limited to these gear ratios due to the independent rear that i do not want to ditch at this time. Is 6500 too high to rev on an untouched 02 5.3? i have a buddy that beats the absolute **** out of his identical 5.3 in his 02 ss and no problems but its not boosted.. Only mods i was planning on doing was a cam, lifters, and valve springs.... anything else i should consider?
Old 01-06-2012 | 09:51 PM
S10xGN's Avatar
Billy Godbold @ Comp spec'ed me just the opposite profile for my turbo Buick (GN) engine. I ended up with a 215°/210° duration cam for a 235" motor. Of course, the heads breathe completely different, but the principle should be the same.
Old 01-07-2012 | 12:44 AM
wildcamaro's Avatar
Thats interesting, I think the ability of the newer heads is why the added intake duration isnt needed, but i havent worked with a ton of buick motors so im not sure if thats why, thats just what my gut tells me
Old 01-07-2012 | 09:28 AM
JPH's Avatar
JPH
230+ @.050 range if peak power is desired past 6200k.
