New cams from Tick Performance
Old Oct 15, 2013 | 05:55 PM
  #761
ironmanLS1's Avatar
Martin - as requested shot you an email. Let me know when you catch a breather.
Old Oct 15, 2013 | 07:30 PM
  #762
Trannysgonewild12's Avatar
what cam can i put in my ls1 without changing the lifters,push rods,valve springs and the converter! im looking for a drop in cam with a chatter !!! can anyone refer me to one?
Old Oct 15, 2013 | 08:47 PM
  #763
b0b's Avatar
b0b
Are you serious? You might be able to get away with lifters depending on our mileage, but springs and pushrods are not negotiable with a cam. They're a must. Don't cut corners unless you want your motor to be dead in a few hundred miles..
Old Oct 15, 2013 | 09:00 PM
  #764
Sales@Tick's Avatar
Originally Posted by Melba LS1
Hi all I'm a self confessed cam aficionado with my first LS1 doing my full homework as we do before I jump in and take a dive. I really want to see somebody's testimonial on the street heat stage 1 as I believe that is the cam for me. Surely someone has this cam installed ? I have been lurking here for a while on this forum before joining up but I can't find a razoo of info apart from the advertising claims....All the other grinds look way to big for my daily driver, stock stall A4 4dr sedan.....can anybody enlighten me please ?
Or you could just ask me.
I would prefer to specify you a custom camshaft that would meet your unique requirements.
Originally Posted by Rogue Status
Looking for recommendations. I was impressed with the knowledge you dropped in denmah's truck build thread a while back and told myself I would get a cam from Martin when the time comes. Well I just swapped a 5.3l into my '81 Volvo 245 wagon. Onto the specs:
- 2002? 5.3l
- 799 heads
- LS1 intake
- Hooker Cast Manifolds
- 2.5" exhaust through an x-pipe into a Cherry Bomb turbo dual in single 3" out
- T56
- 3.73 gears
- Vehicle weighs ~3200lb
I want something aggressive, but that will take daily driver duties in stride. I drive this car to work everyday. Not concerned with lope at idle, I would rather have a steady idle. Would like to see some solid gains though. Willing to put springs in, but don't want to have to worry about PTV clearance.
Thanks in advance! Hoping there is something off the shelf that will work.
The best OTS camshaft I have available in stock would be the SNS Stage 1 camshaft. 223/227 .610"/.614" 111+2.
I had a customer make nearly 400rwhp/380rwtq with this cam in a 370 with Patriot Performance heads and a stock LS6 intake through an unlocked converter.
He ran 7.60's in the 1/8th with tire spin and a baby cam!
It would work well in a 5.3 IMO for a hot street/strip DD vehicle.
Reply sent.
I do not sell camshafts that utilize stock springs. I just don't follow that method, sorry.
I can make you a great deal on a cam package with Comp push rods, BTR Platinum springs and a SNS Stage 1 cam though.
Old Oct 17, 2013 | 12:41 PM
  #765
Sales@Tick's Avatar
What are the specs on the Howards Hotcam and Comp XR265?
Old Oct 17, 2013 | 05:07 PM
  #766
99Bluz28's Avatar
Howards #197245-12, advertised duration(.006") 267/276, .05" duration 219/228, lift .525"/.525", lsa 112, icl 108 .
You definitely can't use any LS6 valve springs with these lobes.
Old Oct 17, 2013 | 08:10 PM
  #767
kylemm1002's Avatar
Anyone have any more vids of the sns stage 3? Found a few on YouTube from ross(?) but that was about it!!
Old Oct 17, 2013 | 09:05 PM
  #768
97camaro383's Avatar
Originally Posted by StormTrooperZ06
Hey guys heres a tuned idle clip and revs. Love the cam, it just pulls so freaking hard like a train! I just gotta fix the clutch sticking pedal issue and then ill make a drive vids
Cammed C5 Z06 Revs!!! - YouTube
Thats me! I've only made a few boring videos of idling but once I get a new converter in the car, i plan to dyno it. Above is another person with a sns stage 3 that posted earlier in the thread
Old Oct 26, 2013 | 12:03 AM
  #769
Coonass350's Avatar
Martin, if one had the LS1 SNS Stage 2 and they decided to swap it out for the SNS Stage 3, what would be the outcome? how much more power/tq would it add? CNC heads, fast 92/92, arh longtubes & ory, UD pulley. Only change would be going from the SNS Stage 2 to the Stage 3.
Old Oct 26, 2013 | 10:54 AM
  #770
FEAR LS's Avatar
Exactly what I would like to know as well. I'm looking to do a cam swap. I will more than likely have to PM/Email/Get a hold of you in some form to where we could talk about the specifics. I do love the torque the SNS has, I would love to keep that same agenda while being bigger and the 150 shot. (More of a track only cam for a while. So the biggest I could fit, even if flycutting is an option)
Old Oct 26, 2013 | 11:55 AM
  #771
jsteele90's Avatar
anyone here have any experience with Martin@Tick custom cam. he specd me a 229/237 .615/.610 @ 111+3 lsa.
Old Oct 26, 2013 | 11:59 AM
  #772
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Sounds familiar to me,
It'll perform, that's for sure, if that's what you're asking.
Extremely similar cam I had was good for 460/420 in my Camaro (m6) This was with AFR 205's and a stock FAST 92.
Old Oct 26, 2013 | 02:08 PM
  #773
hodge9386's Avatar
i know iv read it in here somewhere but i forgot what you recommended. what do you recommend for a m6 car with 4:10 gears and full bolt ons for now? later i would like to get some tfs as cast 220's with turned down ls3 valves and i fast 92. will a cam that works good for those heads still work good with bolt ons for now? this is a street car btw, will prolly never see a track again. also what cc should i mill the tfs 220's to?
Old Oct 27, 2013 | 09:39 PM
  #774
Sales@Tick's Avatar
I would expect 20rwhp/15rwtq at the absolute least.
SNS Stage 3 is a beast for sure.
The custom cam I mentioned to you is also extremely powerful as well.
I have a 235/246 .621"/.595" 112+3 if you want to get really nasty!
For something like what you're describing I would recommend this camshaft:
229/239 .615"/.610" 111+3
Old Oct 28, 2013 | 12:39 AM
  #775
Coonass350's Avatar
Thanks Martin for posting up and letting us know the power difference in the Stage 2 & 3. I am not real sure which I want to go with though..Stage 3 or the custom you mentioned in the pm. Going to chew on it for a bit. I am assuming they would drive almost identical, just more top end power with the custom cam?
Old Oct 28, 2013 | 12:45 AM
  #776
JakeFusion's Avatar
Super Hulk Smash
Hmm...
I was thinking of doing that profile when I go with a forged bottom end and a ProCharger... but on a 115+3.
Old Oct 29, 2013 | 11:27 AM
  #777
Sales@Tick's Avatar
Hmm...
No where near enough EVO.
Too much overlap.
Think of the pressure differentials in the intake port and exhaust port of a centrifugal blower. Then re-think your overlap figure.
227/247 115+5 is what I'd do for that set-up personally as a max effort camshaft. Honestly, a 227/243 116+6 would be perfect.
Your IVC is too late in that profile. Much too late. There is no gain going past 46 ABDC with a stock stroke and long runner intake unless you have stupid amounts of compression.
Old Oct 29, 2013 | 02:15 PM
  #778
derekbuckner1's Avatar
Ordered my sns stage 3 last night
Old Oct 29, 2013 | 02:49 PM
  #779
StormTrooperZ06's Avatar
Congrats, ya gonna love it
Old Oct 29, 2013 | 04:46 PM
  #780
We need some more videos of the vette at WOT
