How much will a stock block take
Seems to me that a lot of peeps have been flirting with disaster and getting away with it for years then. Many are spraying up to a 300 shot with good tuning and high octane gas, and have gotten away with it for a long time. I wonder how they managed that?
The block itself can handle 600>700, provided you do not run into detonation, or crancase pressure problems, especially a well aged and cured block.
Spend as much as you can into a pro machining job for blueprinting, tolerances and balance and you should have no problems.
IMO it is Head sealing I would be more worried about.
Wade Stevens's car (98 Z) has over 1000hp on a 400+ shot DP.
All of this on a 422 LS1 (Not so stock)
and what about those FI cars like the LPE twin turbo Corvettes? As well as many others who have fairly reliably been putting down at least 700 to 800 RWHP? Most all of the component failures that I read/hear about are related to pistons/rods, or valve train. I would personally be much more concerned about my upper end components having a problem before the LS1 seasoned block that was used in my 422 build. Not that I want to tempt fate and spray some crazy 400 or 500 shot of N20, but I think that it will take a 250 shot with good tuning & race gas. I cannot afford to grenade this new motor, so plan to stay N/A for several thousand miles to make sure there aren't any issues that crop up. After a few dozen passes N/A and a few thousand highway miles, I plan to gamble with some N20, and I wonder what other peeps here think would be the biggest shot a well built stroker would handle?
<300>
And much, much more. . . anyhow, I wouldn't be spraying it "repeatedly". Only on occasion, and only with the proper tune & octane in place. 300 shot has been mentioned before, but I think maybe starting out with less, like a 150 NX shot into the intake, then if and when we step up to 250/300, go with a Direct port. Maybe the LSX intake will have the issues solved by then and I can get a 90 mm setup and use that to set up a DP.
