Patriot 243 heads pushrod length help?
I got a set of Cnc ported patriot heads from my buddy's wrecked zo6.(he bought it already built) I'm trying to find out the specs on the heads. The numbers patriot heads 1256 4243? anyone familiar with these heads? I know for sure there Cnc ported not sure if there milled. His zo6 put down 670 rwhp 383 stroker, blower cam duration was 240/230 and 9psi of boost from his vortech supercharger. His push rod length was 7.350 does that mean the heads are milled or just from the high lift cam????if so how much??? I bought 7.40 length push rods intending for just a cam swap until I found these heads. So the 7.40 rods probably won't go with my heads and cam swap on my 99ss???my question is why would someone get the heads milled for more compression on a boosted motor?
Anyone? Since the motor was running 7.350 length push rods the heads were milled right? Or does the high lift blower cam (240/230) have anything to do with the push rod length? Because stock is 7.400 length push rod length.
Well of course I'm going to measure it once everything is here. I'm waiting on gasket and head bolts from tsp just trying to have a smooth install by prepping and gathering last minute problems. Like "oh **** wrong pushrods" and be out a daily driver, waiting a week because paying for two day shipping to Hawaii is pointless. These heads came up last minute I was only going to do a cam swap until my buddy totaled his zo6. Just trying to figure out why his motor was running 7.350 pushrods due too a milled head or big 240/230 cam?
Patriot is now Promaxx. Same people. Give them a call, and they will help. I do also have a set of patriot 243 stage three heads. What is the valve size? Also you will probly have to cc the chamber to get an idea on milling.
