lq4 broken pistons?
Most people seem to run 14-20 under boost https://ls1tech.com/forums/forced-in...-able-run.html
This piston chunks most likely went out the exhaust so I would have the heads checked when you rebuild.
Timing varies from engine to engine but you'll likely need pull timing as you make more boost. So you may start at 16*-18* at idle and end up at pulling 4*-6* or more depending on boost levels.
