Tick SNS Torquer Stage 2 users Come On In!
Old Sep 25, 2014 | 12:31 PM
LS1nut346's Avatar
Default Tick SNS Torquer Stage 2 users Come On In!
Ok so since this cam is so popular, I'm thinking it would be great to set up a thread where everyone can post their results. Since the cam is for ls1's, please only report if you have stock LS1 displacement. I'm thinking the format should go like this:
Tick SNS Stage 2 cam Version (Regular/Mild):
Heads:
Ported? If yes, by who?:
Chamber size:
Head gasket:
Flycut? if so, how much?:
Exhaust, intake mods:
Rear gears:
Dyno HP/TQ:
Type of dyno? (i.e. mustang, dynojet):
Track Times and Speed:
Thanks and I'm looking forward to the results. I think this will help not only me but lots of others thinking about this cam. Feel free to post graphs.
Old Sep 25, 2014 | 01:06 PM
FEAR LS's Avatar
Tick SNS Stage 2 cam Version (Regular/Mild): Regular
Heads: 799
Ported? If yes, by who?: TEA Stage II
Chamber size: 63cc
Head gasket: .051"
Flycut? if so, how much?: No
Exhaust, intake mods: TSP 1 7/8-Borla Adj. Catback, Fast 92
Rear gears:4.10
Dyno HP/TQ:461/435
Type of dyno? (i.e. mustang, dynojet): Dynojet
Track Times and Speed: 7.71@94mph 1.8X 60'
I would add Transmission and rear end as well, and for the auto's what size stall... I was T56, with stock 10 bolt
Old Sep 25, 2014 | 01:18 PM
LS1nut346's Avatar
Good call. great results BTW!!
Revised list:
Heads:
Chamber size:
Head gasket:
Flycut? if so, how much? If no, what was your clearance?:
Rear gears:
Rear (i.e 9", S60, 10 bolt etc)
Auto or manual trans:
Dyno HP/TQ:
Old Sep 25, 2014 | 01:27 PM
whatsa347's Avatar
Wow, you have the best results I've seen with the SNS stage 2 by far. TEA heads, once again, making good numbers.
Old Sep 25, 2014 | 01:32 PM
FEAR LS's Avatar
Thanks man.. You can hear the idle clip of my car on Ticks website under the SNS Stage 2 cam. The car had a lot of useable power. Made a lot of smiles and broke some hearts on the streets. Then I was bit by the Drag Racing bug... Needed a bigger cam after that.
Old Sep 25, 2014 | 04:15 PM
Rise of the Phoenix's Avatar
I have the SNS Torque Max 2, regular (non-mild) version. I'm running that cam with Advanced Induction Dart/RHS CNC'd heads, milled down to achieve between 11:1/11.5:1 compression. Stock LS6 intake and TB. Long tubes with 3" Texas Speed duals, SLP lid, no MAF (SD tune). Runs like a rabid dog on meth. Made 420 on a very conservative dyno.
The power band is great. The idle sound is also great. Just make sure you set the idle around 800 to 850 rpm's. This cam, with a good tune, is very easy to drive. I don't daily drive my car, but if I had to, I wouldn't have any issue doing so. I also have a Monster stage 3 clutch with Tick master/speed bleeder. You'll at least need a Tick master cylinder. I did not have one at first, and my clutch pedal was always stuck on the floor. I then decided to just go ahead and put a great clutch in too for future HP/TQ.
Old Sep 25, 2014 | 09:32 PM
LS1nut346's Avatar
SO..
Heads: Dart/RHS
Ported? If yes, by who?: no
Chamber size:??
Head gasket:??
Flycut? if so, how much? If no, what was your clearance?: ???
Exhaust, intake mods: TSP duals and long tubes, LS6 intake
Rear gears: ??
Rear (i.e 9", S60, 10 bolt etc): ???
Auto or manual trans: ???
Dyno HP/TQ: 420 hp / ?? tq
Type of dyno? (i.e. mustang, dynojet): ??
Track Times and Speed: ???
Old Sep 26, 2014 | 12:30 AM
Mark01Ws6's Avatar
My 231/235 sns stage 2 (cam only) is being installed this week. Should have dyno results mid week. Anxious to see what it puts down. Most I see are running this cam with heads. Being conservative I am gonna expect maybe 365whp on Mustang Dyno.
Old Sep 26, 2014 | 08:05 AM
[QUOTE=LS1nut346;18446127]SO..
Tick SNS Stage 2 cam Version (Regular/Mild):Regular
Heads: Dart/RHS
Ported? If yes, by who?: Yes, fully CNC ported by AI
Chamber size: 11:1/11.5:1 compression (not sure what CC they ended up being)
Head gasket: MLS gaskets (.52 I believe)
Flycut? if so, how much? If no, what was your clearance?: No
Rear gears: 3.42
Rear (i.e 9", S60, 10 bolt etc): 10 bolt
Auto or manual trans: M6
Dyno HP/TQ: [B]420 hp / 390 (only 3 dyno pulls, no dyno tuning, all street tuning)
[/B]Type of dyno? (i.e. mustang, dynojet): Dynojet
Track Times and Speed: No track times
Old Sep 26, 2014 | 08:13 AM
JakeFusion's Avatar
Super Hulk Smash
So you made 464rwhp and only managed a 7.7 @ 94? Did you have any suspension mods? Did you ever run it again?
Old Sep 26, 2014 | 09:32 AM
FEAR LS's Avatar
I had no suspension mods other than some lca's. Even in the video I have you can see the weight transfer is horrible. I was on a 315/40-17 Nitto 555R tire... So it wasn't the cars lack of power by any means. I put a ET street on it, and snapped the driver side axle as soon as the light hit green.
The car now runs a 6.47@106.8 (on a 122rwhp shot) with a 1.43' 60' in case you were wondering.
Attached Thumbnails Tick SNS Torquer Stage 2 users Come On In!-time-slip.jpg
Old Sep 26, 2014 | 11:46 AM
JakeFusion's Avatar
Super Hulk Smash
Hmm. MPH still seems low. What's the DA? Like 5000?
Old Sep 26, 2014 | 12:09 PM
2002 blue z28's Avatar
Heads: 243
Ported? If yes, by who?: PRC Stg. 1
Chamber size: 64cc
Head gasket: .040 Cometic
Flycut? if so, how much? If no, what was your clearance?: No, didn't measure
Exhaust, intake mods: 1 7/8 LT, ORY, Magnaflow CB, FAST 92/92
Rear gears: 3.73
Rear: Stock 10 bolt
Auto or manual trans: Auto
Dyno HP/TQ: 428/378
11.97@116 MPH
Old Sep 26, 2014 | 03:48 PM
FEAR LS's Avatar
Yes, DA was around 4400. Great DA at my local track is like 3300. lol
Old Sep 27, 2014 | 08:13 PM
BlueBird346's Avatar
Are you putting it in an ls1? If so, I did the same thing. Decided to be different. Love this setup and drives almost like stock, even with the 3.42s. Check my sig.
Old Sep 27, 2014 | 09:39 PM
Here is a video I made today so you can hear how the cam sounds.
Old Sep 27, 2014 | 11:17 PM
Sales@Tick's Avatar
DA is a killer. 99.42 is his corrected MPH and 7.27 is his corrected E.T. to sea level. That is for mildly modified engines according to Wallace. 97mph is extensively modified engines and 7.36 ET.
Seems about right to me.
Old Sep 27, 2014 | 11:21 PM
Mark01Ws6's Avatar
BlueBird436,
Yes it's factory LS1. 56k miles on Odometer. Is that your car under MrSweetLsx on youtube?
Going by the format minus the dyno and track times since car isn't done yet.
Tick SNS Stage 2 cam Version (Regular/Mild):Regular 231/235 version
Heads: stock 241's
Ported? If yes, by who?:No
Chamber size:Stock
Head gasket: Stock
Exhaust, intake mods: P&P TB, LS6 Intake, Lid, 1 3/4 LT's, ORY, Borla Adj Catback
Rear gears: 3.23
Rear (i.e 9", S60, 10 bolt etc) 10 Bolt
Auto or manual trans: Auto, 3600stall
Dyno HP/TQ:404/376
Track Times and Speed:11.97@113.41
Old Sep 28, 2014 | 01:49 PM
BlueBird436,
Yea that's mine. Just curious because I haven't seen anyone else use the 231/235 version yet.
Old Sep 28, 2014 | 01:57 PM
Guess I'll jump on since I kinda hijacked the thread.
Tick SNS Stage 2 cam Version (Regular/Mild): 231/235 111lsa version
Heads: LS6
Ported? If yes, by who?: stock w/ competition valve job by a competent local machinist.
Chamber size: ~63cc
Head gasket: stock .050(block was decked so quench is around .032".)
Flycut? if so, how much?: no
Exhaust, intake mods: FAST 90/92, TSP 1 7/8, ORY, dumped bullet
Rear gears: 3.42
Stock rear, M6
Dyno HP/TQ: 456/417
Type of dyno? (i.e. mustang, dynojet): dynojet
Track Times and Speed: none yet, still breaking in engine
