Starting my cam swap this weekend. Do I have everything?
Hey guys, starting my cam swap on Friday and just making sure I have everything, pretty sure I do.
Cam, valve springs, pushrods, ls7 lifters, comp rocker upgrade kit, tsp oil pump, double roller timing set, gasket kit
Anything I'm missing other than oil and antifreeze?
If I was pulling the heads to put in lifters, I would use a better lifter than the LS7. That's a lot of work for a stock replacement lifter.
Not that I want to get into a lifter debate...
What cam are you installing?
Have tick street heat stage 2. 231 235.
Yeah should have gotten different lifters but cars getting a different motor down the road so wasn't a big deal just wanted to get the original ones out. And have a almost new top end.
Nice, I almost got that cam. Can't wait to hear your results.
Well might leave heads on for now and wait til I get some 5.3 heads and can save for some arp studs, with that in mind what size dowl or rod do I need to hold the lifters up while the cam is out or are there some other tricks to keep them up?
