texas speed camshafts
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
https://physics.stackexchange.com/qu...e-diameter-o-d
"This means a hollow cylinder is stronger than a rod of equal mass and the same material. A hollow cylinder with a bigger inside diameter is better. In the limit x→1x→1 the hollow cylinder is twice as strong. Note that this limit isn't physically viable as it would be an cylinder with infinite radius and infinitesimally thin wall."
The key as I understand this based on what was written in the link is a hollow cylinder of equal mass is stronger than a solid cylinder of the same mass. If we have 2 pounds of steel we can make a stronger 2 pound hollow cylinder that is say 20 inches long than a 2 pounds solid cylinder that is say 20 inches long. The 2 pound solid cylinder will have to be of smaller diameter than the 2 pound hollow cylinder.
It didn't say a hollow cylinder of the same diameter is stronger than a solid cylinder of equal diameter despite that being the topic heading.
I'm open to correction...
Removing mass by gun drilling the cam is good for performance since we have less mass to rotate.
Open mouth, insert foot.
Arrow manufacturers used this science toward the end of the aluminum arrow erra. Fatter, thinner wall arrows flew faster in some cases without giving up due to side force. More surface area, I'm sure took some of that back but I guess not all.
A solid 1" camshaft will be stiffer than a 1" hollow camshaft but the 1" hollow camshaft will have less MASS. When you look at a shaft in twist the stress at the center is zero and the highest stresses are on the outside surface and the stresses follow a linear curve. That is why you take material out of the center with minimal loss of stiffness, but there will be loss.
