Camapalooza Camshaft Dyno Test Marathon!
#121
All praise Cam Motion for this learning experience! But since someone brought up absolute stump pullers...
I've been thinking about this for awhile. I have a 2000 2500 with the LQ4, so I got the tiny LM7 cam at 114 LSA and iron heads. I kinda like it this way since the truck is a stick shift and it pretty much always has torque, but I know the 6.0s can take waaaay more cam than that. However, as beefy as the NV4500 is, it doesn't like to spin 6 grand plus...
*I hate to bring up a cam that isn't Cam Motions, but since someone mentioned something like 210 intake lobe with a tight LSA, here is one*
Callies Performance 180-009. It's 210/218 at 108LSA and ground with +3 advance giving:
IVO: 0* BTDC
IVC: 30* ABDC
EVO: 40* BBDC
EVC: -2* ATDC
Looks like many a trees could be pulled: Callies New .552 lift Camshaft series Dyno Tested in 2003 5.3 silverado. - LS1TECH - Camaro and Firebird Forum Discussion
I'm thinking reeeeeeeal hard about getting one for my truck.
IVO: 0* BTDC
IVC: 30* ABDC
EVO: 40* BBDC
EVC: -2* ATDC
The following users liked this post:
G Atsma (07-08-2021)
#122
IVO: 0* BTDC
IVC: 30* ABDC
EVO: 40* BBDC
EVC: -2* ATDC
IVO: 0* BTDC
IVC: 30* ABDC
EVO: 40* BBDC
EVC: -2* ATDC
Part# 03-01-0198
Grind # XA208/325-XA214/325-10+4
High Performance & Off-Road
Duration at .050: 208/214
110 Lobe Center Angle with a 106 Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .553"/.553"
-2 IVO
30 IVC
41 EVO
-7 IVC
The difference is that the Titan 1 Truck cam has 7 degrees less overlap, so it will idle better and have better throttle response. This will be especially important when running the tight stock truck torque converter.
What is impressive is that this is with the big 823 rectangle port heads, It will be even torquier with cathedral heads.
The following 5 users liked this post by CAMMOTION PERF:
07SGguy (07-08-2021), 68Formula (07-09-2021), blackdak318 (08-01-2023), G Atsma (07-08-2021), SoCalDave (07-09-2021)
#123
Insane? Absolutely not. Trying stuff is fun. If you want it, I will make it. But, because the specs are so unusual, I don't have any cores on the shelf that will make it. So, we would have to make it from scratch. This is not problem, but these "one-off" cams cost $650 and take about 8 weeks to make.
This thread is a blast! Looking at the tested cams does stuff like the above speculation/goofing off.
Gearhead food....
#124
I think the Titan 1 Truck cam is an even better choice:
Part# 03-01-0198
-2 IVO
30 IVC
41 EVO
-7 IVC
Part# 03-01-0198
-2 IVO
30 IVC
41 EVO
-7 IVC
Looking at it again, the Titan 1 would be pretty ideal.
I saw a vid of someone with the callie and it had a decent lump at idle. I'm kinda trying to be a sleeper so less chop with your cam would be the bumble bee's knee caps!
G Atsma (07-09-2021)
#126
It would need the same valve placement as the cathedral head so it will fit smaller bore heads. Essentially, a cathedral head with rectangular ports. Doable, but to what advantage when there are cathedrals that almost outperform LS3 heads?
#127
Stock LM7 is supposedly 190/191 on 114 ... I'll assume 114+0
That gives -37.5 degrees overlap at .050"
IVC 29ABDC, EVO 29.5 BBDC, IVO 19 ATDC, EVC 18.5 BTDC.
If I was **really** going to do a towing cam for my LM7, I'd probably want something like the 208 lobes above, but on a 109 LSA.
That would give -10 degrees overlap, and IVC 33, EVO 33 ... the slightly later IVC would allow 4.8 pistons in my LM7 for a little more compression, and probably better fuel economy. The -10 overlap would probably help the idle and low end compared to the crazy 104 LSA in the cam mentioned above.
Just for fun, one cam you could build with a 104 LSA would be a 208/208 104+0. This would have essentially the same IVC and EVO events as the stock cam in my LM7, but 0 overlap at .050” instead of about -38 degrees. Since the lobes are 208 degrees duration rather than the stock LM7 191-ish, you’d be able to gain some valve lift.
In an otherwise stock LM7, I suspect this might be a nice towing cam. Not sure if the 0 overlap would lead to any noticeable idle. Not sure if this cam would have *any* more top end than the stock cam, even with the added overlap, since IVC and EVO are near stock.
Actual towing cams offered seem to utilize later IVC and earlier EVO and wind up with a bit more duration and wider LSA (110-ish seems common). I suspect that this is because people who buy “towing cams” want to see more power even at 6000 rpm, despite the fact that this has nothing to do with real world towing.
I’d be curious to hear input from CamMotion re: tradeoffs between the cam I suggested here and the towing cams commonly sold.
The following 3 users liked this post by Darth_V8r:
#128
Part# 03-01-0198
-2 IVO
30 IVC
41 EVO
-7 IVC
Part# 03-01-0198
-2 IVO
30 IVC
41 EVO
-7 IVC
Currently I have the TSP Stage 2 truck cam low lift 212/218. It is not so much a specific cam on this thread that makes me want to change but looking at cams makes me want to change haha
If I have to do something different I think I would go a little larger and go high lift. When I went to swap cams originally I had my eyes on that Summit 218/227 low lift or high lift and I almost pulled the trigger but changed my mind. I think a little less power in the low end and some more in the top end would make it a tad more fun. I don't floor it every day but I like to give it the juice every now and then and I just wonder maybe I should have went for something a little bigger. Especially with some extra mods like a different intake, heads etc etc
Some may call me dumb but I do enjoy the hot rodded sound and the looks you get when you have a little more chop. This factors in a tiny bit.
I had the same TSP low lift truck cam in my 08 Sierra, it was my first cam swap on an LS and I was happy with it for what it was. I was coming from a diesel but that was getting expensive and needed injectors and the amount, weight, and distance I tow theses days has dropped way off so a gasser will do me just fine. Picked up a 2500 2x4 and had been eyeing this cam and swapping on a set of 799's I have onto the 6.0, this might just be the kick in *** I need to finally place the order.
#129
Y'all are basically talking about diesel cams. Helped a friend swapped a 185/188-106 into a Dmax. Makes you appreciate the LS. Although I do like the timing gears. Harder to screw up. Only .420 lift on the thing too.
IMO, you want to make a 5.3 a stump puller, go small on the cam and put a big nasty blower on it.
The following 2 users liked this post by BCNUL8R:
Darth_V8r (07-09-2021), SLOW SEDAN (07-09-2021)
#130
And yet other old guys who prefer N/A setups will use the milder cam with more low and midrange torque to clean the clocks of grossly over-cammed, peaky builds because their owners HAD to have shaking-like-a-dog-crapping-peach-seeds chopping cam so the peanut gallery can hear what great engine builders they are.... lol
The following 4 users liked this post by LilJayV10:
#131
#132
We aren’t allowed to talk about boost or high rpm power in here. When you drive 1000 hp cars on the street and can blow the tires off at 80 mph without down shifting you become willing to trade some low rpm TQ for high rpm power. Not everyone realizes some people have different goals or are willing to accept any goals that differ from their own. But I’m just a “boy” and a “red neck” even though I actually race and drive my car in the street too.
#133
question for cammotion,
I don't want to derale the thread, cause that hasn't happened as of yet,
But my question is regarding VVT cams.
Why don't we see more of them?
The concept sounds good on paper, but in the real world, is it not worth it?
This is probably the best thread i've seen on LStech this year.
#134
The following 2 users liked this post by Che70velle:
CAMMOTION PERF (07-09-2021), G Atsma (07-09-2021)
#135
VVT does work and does have its place for sure. VVT has more limitations in a single cam engine compared to a multi-cam engine that has a separate intake and exhaust cam. This is because when you move a single cam, the intake and exhaust valve events all move the same amount together. They can't be controlled separately like they can in an engine like the Ford Coyote that has separate intake and exhaust cams.
From my experience, smaller duration cams lend themselves to and respond better to a VVT scenario than larger duration cams in a single cam engine. Since most of what we do is performance work, there is not much call for smaller VVT cams. We do have some smaller duration VVT offerings for the Gen 5 LT
Also, Gwatney Performance has some VVT grinds that they had success with. You might check out their offerings.
G Atsma (07-10-2021)
#137
It surprises me that there isn't more excitement around VVT in performance cars. For big cams I can see PTV issues being a problem, but my intuition says it should be possible to give a medium-ish cam an extra-wide powerband and some more top end with VVT. Like say 228/232 @ 112, and move the intake centerline from +6 at low RPM to -4 at high RPM.
#138
The 243s became available at the end of testing. So, they were not tested with very many cams. Mainly they were put on out of curiosity to see how they would compare against the 706s and 823s. Also, when we swapped over to the 243 heads, one of the ARP head stud broke during torqueing to spec.. That cost us some dyno time which was scheduled to end that day.
Here is a mostly, "kinda fair" dyno test between 706, 243 and 823 cylinder heads on a junkyard 6 liter with a cam.
What makes it fair:
All the exact same short-block on the exact same dyno.
Same Carburetor.
Same Headers
Very similar intake manifolds (Super Victor cathedral vs Holley 300-291 rectangle port)
What makes it a little unfair:
The 243 heads had a fresh multi-angle performance valve-job whereas the 706 and 823 heads had a factory valve job.
The 823 head test had a 232/244 cam whereas the others had a 236/244 cam.
What makes it fair:
Same Carburetor.
Same Headers
grubinski (07-12-2021)
#140
I understand that but I'm trying to chase torque and low end response though with my other 6.0 combination because it simply cannot use RPM it needs to work in that low low untestable lol low RPM range 750-2000rpm where the 706 heads on a flat top 4.065" bore with stock F-body manifolds isn't really choking it to death at all works very well in that range, the car has amazing response just a light touch of the toe and the speedo needle starts twisting and a big hurry, I started with a 212-218-115 + 0 and moved up to a 226 230 112 +4 both of these have the same IVC of 41 idle perfect at 666 RPM and give me no issues with detonation on 93 under load with the tall gears or anything .
This is where all my fun is also, little harder to find info on these cams...Us 2500HD guys really like the torque...
