Eldebrock Heads and 234/242 Cam
I purchased some eldebrock heads with 11 to 1 compression. The intake is 2.02 and exhaust is 1.57. The exhaust runners are 83cc. The heads have dual springs with a 660 lift. It was recommended that the dual springs be shimed to within .050" of coil bend. The intake is a 90 Fast with 90 NW TB. Car has true duals and Yank 4200. If a go with a cam spec at 234/242 .598/.610 110 LSA +4 Adv will I have any V to Piston issues. Your assistance with this is appreciated.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Originally Posted by SVT THIS
Just curious, what are the intake runner sizes on those heads? You could flycut, or spend some more cash and get some -cc forged pistons and throw in some rod bolts so you can spray and spin without worry.
Originally Posted by Kent1
So I need to use .060 gaskets with this cam. Is there any other to know.
TTT....TTT
TTT....TTT
Ben T.
