LS Pro Shaft Rockers
Crane Cams is proud to announce that our new “LS-Series Pro Shaft-Mount Rockers” won a Global Media Award at the recent 2007 SEMA Show. Global Media Awards are awarded to new products that are judged to be “significant new products for the international market.” The LS Series of GM engines is certainly an “international engine platform” and our new Pro Shaft-Mount Rockers help maximize power and reliability from this outstanding engine design. The “LS-Series Pro Shaft-Mount Rockers” are available in 1.7 (Part # 1448101-1) and 1.8 (Part # 1448102-1) ratios. These new rockers kits are loaded with specially engineered features that set them apart from the competition:
· Mikroniteâ processed 2024T8 rocker bodies for high strength and low weight.
· Mikroniteâ processed 8620 carburized steel rocker arm shafts for high strength and low friction.
· Polymer-matrix composite bearings eliminate “internal friction”, “bearing inertia” and “sewing machine noise” associated with needle bearings.
· “Quick-Lift” rocker body geometry opens the valves quicker to establish flow into the cylinders and closes the valves quickly to maximize cylinder pressure.
· One-piece, Mikroniteâ processed, steel shaft stand to take the pounding of lash changes due to the dimensional changes of aluminum engine castings as they change temperature.
The new rocker kits are available for shipment. Also available for immediate shipment are our Sportsman LS-Series Shaft-Mount rockers: 1.7 ratio, #144809-1; and 1.8 ratio, 144808-1. Call our tech department for the special pricing today! (386)258-6174.
[IMAGE:flag:A=LEFT]
http://vincihighperformance.com/SHAF...0.HTMLPAGE.htm
oh okay-
so for a high end user-u would be better off getting a jesel set that fits that head-
