biggest cam on ls1 w/ dart 225?
just as the title says, what is the biggest cam you can match up to a set of dart 225 heads with a stock ls1? they are 62cc heads, have some porting but no milling.
would like to run something like a trex
how much do most shops charge to flycut pistons?
I would maybe do a search to see if someone is running a similar setup. I also like to check the Dyno threads to see actuall results as well as the dragstip threads....
That way you pick the setup that would work best with your setup.
Also Look up Preditor Z or PAtrick G and they could help you out....
https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
Here you go, this is a good read
i ran a 346 stock short block, g5x4, box stock dart225's, vic jr intake, and a 750 cfm carb setup.. car went 10.6's all last year.. its in the drag race section
its tight very tight but a g5x4 clears
