crackling sound at high rpm's please help
I have a 2002 LS1 and I am getting a crackling sound at high rpm's. I dont think it is detonation because my a/f ratio is right on the 13 mark all threw the rev range on the dyno sheet. If anybody knows what this is or has experienced it themselves please post what you think. Just need to know if it is a common thing or a problem that needs to be fixed.
LS1TECH Sponsor
True, too much timing advance is always more of the culprit rather than being a bit lean when it comes to detonation. Grammer is bad really tired ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Jeremy Formato
Jeremy Formato
i only have a lid, exhaust MSD spark plug wires and double platinum NGK plugs. i havent messed with the timing at all. I have a OBD 2 scanner would that tell me if i am detonating when i do a run?
Restricted User
Dble pltnm plugs suck.
Check to make sure your wires are on tight, double click on the coils, and fully seated on plugs.
Look at timing, over 29* is not normal, as thats stock. KR will tell you tell you how much Knock Retard you are getting.
I would say swap out the plugs and try NGK TR6 as they are a step colder plug and help a lot of people out that have det, issues.
im getting a funny sound that starts around 4,800 till the trany shifts about 5,500 to me it sounds like a valve spring getting weak and my car is stock with 58000miles what do yall think
I have the same crackling noise at WOT ...not sure what it is....I'm currently swapping out intakes and hope it goes away after the new setup is in place...
Stroker2112
Stroker2112
